Thread: pressure torque conversion
    May 2016
    Bang Head pressure torque conversion
    hi all
    can anyone help me to figure up how much pressure (psi) should be applied for this condition :
    i- box wrench size : 60mm
    ii- minimum required tensioning force : 460kN
    iii- maximum required tensioning force : 734kN
    fyi, the item to be tensioning is macalloy bar ( i also not sure what it is)
    plus can show how we can get the pressure value given the torque value is known.
    2,616
    It's just a tie-rod and thread tensioning system...
    See:
    Torque Engineering and Design
    Axial Force vs Torque Design and Calculator
    May 2016
    Lightbulb
    See:
    I still not get what u mean Kelly.
    It given box wrench size is = 60.3mm
    min. required tension force = 460kN ( tensioning force is same for torque applied? or diff.?
    what the pressure, psi should be applied.?
    2,616
    Size of the box wrench is meaningless... Nobody knows the sizes of your hardware...
    The force applied by a screw thread is approximately equal to the applied torque divided by the major diameter and friction constant.
    See: http://www.engineersedge.com/torque.htm
    You should consider consulting an available engineer and/or the tensioning system applications engineer.
