![Quote](images/misc/quote_icon.png)
Originally Posted by
jboggs
You want a pilot-operated check valve ("PO check"). Installed directly in the cylinder port, it will prevent flow out of that port unless pressure is also supplied at the other port. It only allows air to flow out of a port if there is a positive pneumatic signal (pressure) supplied to the other port. Any industrial pneumatic distributor can help you with plumbing, etc. You can get them from Clippard, Bimba, Mead, Pneumadyne, Parker, Festo, SMC, and many others. They're available for both pneumatic and hydraulic applications. Make sure you're getting the right type.
