Results 1 to 1 of 1
Thread: Help with with a problem! Looking for a genius!
    Jul 2017
    Guys, I am looking for some help!
    I am about to attempt to build a frame that be covered with tread-plate to become vehicle ramps for a recovery truck. I want these to be as light as possible but strong enough for the pair to carry 1600kg.
    I have attached a picture. Diagram "A" is the usual frame that would be used to support one wheel of the vehicle. This would be a very heavy, but strong box steel (50mm x 50mm). Diagram "B" is me thinking of using some kind of weight spreading structure so I can use much lighter steel, maybe 40mm x 40mm.
    Am I right in thinking this structure will spread the weight and will it actually be as strong or stronger if I use lighter gear?
    Anyone got any ideas?
