Thread: Angularity vs Perpendicularity on a Dovetail
    Jul 2018
    First post is a question :/
    I am trying to establish the right way to control the 90deg feature of a dovetail.
    I'd think creating one side as a datum and then calling out perpendicularity to that for the other surface would be the best method. But I've been told that its not proper, so I am trying to figurre out the right way to do it.
    I've attached a drawing indicating my two ideas.
    thanks!
    2,593
    I think that without a specification on the required accuracy between the dovetails that a complete and concise answer is challenging.
    However, the method you have shown when applying ASME Y14.5-2009 is correct for both Perpendicularity and Angularity. The 2009 standard, allows for angularity to be used in all orientation application specifications. I suspect that perpendicularity and parallelism will be gone in the nest ASME standard release.
