Thread: Specifying tolerances for multiple features in press fit
    Nov 2020
    I have been Googling on how to specify this, but have not been able to find anything - hope someone can help
    A plastic-piece needs to be molded to make a press-fit into a stainless steel tube (handle).
    The tube is oval and asymmetric.
    The press fit is made with stripes that are deformed in the press-process - see the picture, showing the lower shell of te part.
    How do I specify that the outer points of the stripes must be within a specific tolerance?
    Other tolerances in the part are much more relaxed.
    I have some basic knowledge of GD&T, but not enough for this one
    Tank you.
    Best regards,
    Carsten
    279
    Probably using Profile of a Surface/line.
    See: https://www.engineersedge.com/catalo...oducts_id/656/
    Nov 2020
    Thank you very much for the suggestion, Cragyon.
    I did look at the profile, but was unsure if it was right.
    If using the profile, how can I call out multiple features together with a sigle annotation?
    It looks like Solidworks has a feature for this, but I'm using Fusion 360 - and again, I haven't been able to find a standardized way.
    Thank you.
    Last edited by carsten_olsen; 11-12-2020 at 09:16 AM. Reason: Messed up copy-paste
    2,418
    Breakout a detail view and indicate the number of occurrences that geometry occurs. Using the same datum order of precedence indicates a simultaneous requirement.
    Nov 2020
    Thank you very much, Kelly, for your suggestion.
    That was exactly the kind of input I was hoping for.
