Thread: Datum Letters
    Sep 2022
    Datum Letters
    What’s the reason to have Datum’s A, B, E, F, G, H? C and D is not referenced anywhere on mechanical drawing. Is the a concern? Bad practice? Good reason for it?
    2,622
    With respect to ANSI, ASME and ISO dimensioning and tolerancing standards one can use any letter designator as a datum other than I, O and Q. You can even use double letters like datum "AA" or "ZF" and even combine numbers with letters as typical with datum targets.
    e.g. A1, A2, A3, etc..
    Not using "C and D" would be a preference as there is not a rule on the order of letters chosen for datums. I prefer using the letters in the order given by the alphabet however I know this is not a requirement.
    Sep 2022
    Thank you so much Kelley. You are a life saver.
    The designer might have been using some software like Solidworks, in which datum designators are automatically assigned in sequence as they are placed. "A" followed by "B" followed by "C", etc. If one then later deletes one of those datums, the software does not automatically re-assign the others to keep a full sequence. So you could end up with A, B, C, and E. No D.
