Thread: who is an engineer? aperson having following.......................
    hi,
    which persons are considered engineers.
    a person having BE/BS degree are considered full engineers or a person having MS Degrees are considered engineers.
    thanks.
    A person possessing a bachelor degree in engineering from an accredited engineering school may legitimately call themselves an engineer.
    It really comes down to what you are navigating. On paper, at school, or wading through HR, a degree is important and, of course, the higher the degree, the more knowledge is assumed. Yes, a degree is often a pre-requisite, but not necessarily an engineering degree.
    However, some of the best and smartest engineers I have ever worked with had no college degree. They were highly self-taught and could blow the doors off any school test or problem at work. Usually have a Much broader skill set as well.
