Thread: Runout Inspection between Hole and Arc
    Jul 2014
    Chennai, India
    We have one part with a hole of 0.126" dia and an 0.155" radius portion for a length of 30 deg included angle on the same center. Customer asks for a requirement of Radial runout of 0.003" for Arc wrt 0.126"dia hole.
    My question is, Is it advisable to check runout between hole and Arc which have 30deg included angle?
    Your fast responses are most welcome..
    Regards,
    S.John Jeya Balan
    2,616
    Quote Originally Posted by John.S View Post
    If the runout variations are critical to the fit, form and function of the part feature and mating feature it is.
    Jul 2014
    Chennai, India
    Thanks Kelly Bramble,
    But we are facing lot of difficulties during inspection of runout in this arc because of the arc length is very minimum. So we are unable to find any runout issue. But actually the part have a concentricity of up to 0.011" whereas the runout measures 0.017". Parts measured in CMM since there is no possibility to measure this runout by 1st principle method.
