Thread: Motor torque
    Jul 2017
    7
    Motor torque
    Hi there
    I need to calculate motor speed and reduction on a drive wheel.
    the wheel is 2" diameter and is pulling a wire that is pinched between it and another roller. I'll need 100lbs of pull on the wire. I'll need to pick a dc motor and reducer to get this and we already got it wrong once...
    2,616
    Motor torque minimum = 100lbs x 2" = 200 lbs-in.
    With a 3:1 factor of safety you will need 600 lbs-in motor.
    Jul 2017
    7
    Thanks. Will speed be a factor? Ill want to run that at 200 rpm.
    2,616
    Quote Originally Posted by shiloh View Post
    Yes, you need motor that is torque rated at that rpm or gear it to perform optimally.
    Kelly,
    The wheel is 2" diameter. Wouldn't the moment arm be 1"? So the calculation is 100 lbs x 1" = 100 lbs-in?
    2,616
    Kelly,
    Yes, you're right.. hope the op caught my mistake
