Results 1 to 7 of 7
Thread: Load Capacity of a Rectangular Tube
    Oct 2012
    I am looking to purchase two aluminum 6063 four feet rectangular tube of dimensions 4" x 2" x 1/4". I am going to be mounting linear guides and carriages on the tubes. I am also going to mount an aluminum plate (6061) 2.5' x 2' x 3/8" in dimension. This platform would be used to translate human subjects in the forward and backward direction to test their ****** response. The maximum weight for the human subjects to be eligible for the study is 300 lbs . I would like to know if this tube would be able to support that much weight. Just for your information. We will be inserting a rectangular flat bar within the tube to weigh it down. That way, once we take the flat bar out, the platform could be moved to another location easily.
    If this dimension for the tubes won't work, what are your suggestions?
    Thanks!
    Hi and welcome.
    You have not supplied enough information. Do you have a sketch or drawing of the system?
    Is the plate attached to the tubes?
    How are the tubes supported?
    A whole bunch of stuff is needed before I (we??) can help with this.
    Oct 2012
    Hi there!
    I am sorry if my information was not clear. The top of my platform (2.5' x 2' x 3/8") will be mounted on four carriages that would be driven by the guides. The guides in turn would be mounted on the rectangular tubes of dimension 4" x 2" x 1/4".
    Thanks,
    BK
    1,998
    Quote Originally Posted by krishbaggy View Post
    Thanks!
    Ok, just to estimate I took one tube (4" x 2" x 1/4") and looked to see if this one tube was adequate by itself.
    First, find the moment of inertia..
    Bottom most equation
    http://www.engineersedge.com/materia...a-gyration.htm
    I got 2.976237 in^4
    Then determine Modulus of Elasticity (elastic Modulus) for 6063.
    I used the average properties for aluminum found here:
    http://www.engineersedge.com/manufac..._materials.htm
    10.2 x 10^6 lb/in^2
    Then, I assumed a single point load in the middle and used the beam deflection calculator and equation here:
    http://www.engineersedge.com/beam_be...m_bending2.htm
    http://www.engineersedge.com/beam_be...flection_2.htm
    So, comparing the calculated Stress at the center to the Yield Strength of 6063 Aluminum given at:
    http://www.engineersedge.com/materia...properties.htm
    Yield = 7,000
    One aluminum beam all by itself appears to be adequate to support the 300# load.
    I do not certify this and have only had one coffee this morning...
    1,998
    Also, you could do the same calculation for the plate after determining the moment and other geometry characteristics.
    For more engineering beam stress and deflection equations and calculators see:
    http://www.engineersedge.com/beam_calc_menu.shtml
    175
    With all due respect, the problem is that the OP still hasn't given us a clue as to what the setup looks like.
    As usual a big guessing game.
    If the OP could give us a somewhat clearer picture of this maybe there is some hope.
    It is probably a simple problem which begs for a better description.
    I am with you Zeke, I quit after the OP's second post. It made less sense than the first.
