Related Resources: Engineering White Papers
Corrosion Protection for Space Flight Hardware Design Guide
The purpose of this document is to describe the general corrosion protection requirements applicable to the surface treatment and finishing of space flight hardware. This documnet contains the minimum requirements necessary to qualify materials and processes for corrosion control of space flight hardware. Additional testing may be required to meet the requirements for materials
and processes used in space flight hardware systems.
Materials and processes used in interfacing ground support equipment, test equipment, hardware processing equipment, hardware packaging, and hardware shipment are to be controlled to prevent damage to or contamination of flight hardware.
Open: Corrosion Protection for Space Flight Hardware Design Guide
1. SCOPE 6
1.1 Purpose 6
1.2 Applicability 6
1.3 Tailoring 6
2. APPLICABLE DOCUMENTS 7
2.1 General 7
2.2 Government Documents 7
2.3 Non-Government Documents 8
2.4 Order of Precedence 10
3. ACRONYMS AND DEFINITIONS 10
3.1 Acronyms, Abbreviations, and Symbols 10
3.2 Definitions 11
4. REQUIREMENTS 12
4.1 Corrosion Prevention and Control Plan 12
4.1.1 Materials and Processes 12
4.1.2 Order of Precedence 13
4.2 Classification of Corrosive Environments 13
4.3 Cleaning and Surface Preparation 14
4.4 Performance Requirements 15
4.4.1 Class 1: Seawater Immersion 17
4.4.2 Class 2: Seacoast 17
4.4.3 Class 3: Inland, Outdoor 18
4.4.4 Class 4: Chemical or Microbial-Induced Corrosion 18
4.4.5 Class 5: Indoor, Uncontrolled 19
4.4.6 Class 6: Indoor, Controlled 19
4.5 Process Verification 19
4.6 Metallic Finishes 19
4.6.1 Approved Finishes 19
4.6.1.1 Nickel Plating 20
4.6.1.2 Chromium Plating 20
4.6.1.3 Zinc-Nickel Plating 21
4.6.1.4 Copper Plating 21
4.6.1.5 Silver Plating 21
4.6.1.6 Tin Plating. 22
4.6.1.7 Gold Plating 22
4.6.1.8 Ion Vapor Deposited (IVD) Aluminum . 22
4.6.1.9 Sprayed Metal Coatings 22
4.6.2 Prohibited Finishes 22
4.6.2.1 Cadmium Plating 23
4.6.2.2 Zinc Plating. 23
4.7 Inorganic Finishes 23
4.8 Organic Finishes 23
4.9 Design Considerations for Corrosion Control 24
4.9.1 Cut Edges 24
4.9.2 Drainage 24
4.10 Dissimilar Materials 24
4.11 Faying Surfaces, Joints, and Seams 26
4.11.1 Faying Surfaces 26
4.11.2 Fasteners. 26
4.11.3 Electrical Bonding and Grounding 27
APPENDIX
A Sample Data Requirements Description (DRD) 28
LIST OF TABLES
TABLE PAGE
1 Matrix of Class Environments and Test Methods 16
2 Compatible Couples in Seawater
