Engineering Design Data: Menu - excel calculators > Civil Engineering
Civil Engineering Excel Calculators
Next Page
Pages: [1] 2 3 4 5 6 7 >>
Moving Loads on Bridge Graphical Calculator Spreadsheet
Moving Loads is an excel calculation to determine the loads in a span as a vehicle passes over it. The vehicle can have up to 10 axel loads making it suitable for the assessment of trains as well as wheeled vehicles.
Reinforced Concrete Beam Design per. ACI 318-08 Calculator Spreadsheet
The “Building Code Requirements for Structural Concrete” (“Code”) per. ACI 318-08 covers the materials, design, and construction of structural concrete used in buildings and where applicable in nonbuilding structures. The Code also covers the strength evaluation of existing concrete structures.
AASHTO LRFD Bridge Slab Design Calculator Spreadsheet
This spreadsheet was created to aid in the rapid design and/or checking of Bridge Decks or Reinforced Concrete Boxes in accordance with AASHTO 2004 LRFD.
Wind Loading Open Structures without Roofs Excel Calculator Spreadsheet
Wind Loading Analysis Open Structures without Roofs Excel Calculator Spreadsheet Per ASCE 7-05 Code Using Method 2: Analytical Procedure (Section 6.5) for Other Structures of Any Height
Wind Loading Analysis Chimneys Stacks, and Vertical Tanks Excel Calculator Spreadsheet
Wind Loading Analysis Chimneys, Stacks, and Vertical Tanks Excel Calculator Spreadsheet Per ASCE 7-05 Code for Cantilevered Structures Classified as Other Structures
Wind Loading Cladding Building any Height Excel Calculator Spreadsheet
Wind Loading Analysis Wall Components and Cladding Building any Height Excel Calculator Spreadsheet Per ASCE 7-05 Code for Buildings of Any Height Using Method 2: Analytical Procedure (Section 6.5)
Wind Loading Analysis Design Wind Load Case 4 from Figure 6-9
Wind Loading Analysis Main Force Resisting System Excel Calculator Spreadsheet Per ASCE 7-05 Code Method 2 for Enclosed or Partially Enclosed Buildings Design Wind Load Case 4 from Figure 6-9
Wind Loading Main Force Resisting System Excel Calculator Spreadsheet
Wind Loading Analysis Main Force Resisting System Excel Calculator Spreadsheet Per ASCE 7-05 Code Method 2 for Enclosed or Partially Enclosed Buildings Design Wind Load Case 2 from Figure 6-9
Wind Loading Analysis For Enclosed or Partially Enclosed Buildings Excel Spreadsheet
Wind Loading Analysis For Enclosed or Partially Enclosed Buildings Excel Calculator Spreadsheet - Per ASCE 7-05 Code for Enclosed or Partially Enclosed Buildings, Using Method 2: Analytical Procedure (Section 6.5) for Buildings of any Height
Wind Loading Analysis For Low Rise Building Excel Spreadsheet Calculator
Wind Loading Analysis For Low Rise Building Per ASCE 7-05 Code for Enclosed or Partially Enclosed Buildings Using Method 2: Analytical Procedure (Section 6.5) for Low-Rise Buildings
Next Page
Disclaimer
