Plastic Pump Review
Pump Knowledge Menu | Pump Suppliers
Plastic Pumps Supplier
Plastic pumps are made for applications which require a high level of corrosion or damage resistance due to the operation environment or medium being pumped. Plastics (polymers) can provide a superior broad spectrum resistance to acids, adhesive, chemicals, hazardous, and other caustic fluids. Plastic pumps are available in all pump technologies and configurations. Plastic pumps tend to be lighter than conventional pumps, however have significantly lower maximum operations pressures, temperatures, and flow rates.
Plastic pumps are rated for the same performance criteria as other pumps. Plastic pumps should be selected based on their ability to endure the operating environment and materials being pumped.
© Copyright 2000 - 2010, by Engineers Edge, LLC All rights reserved.
Disclaimer
Engineering Store
Products & Services
CAD Forum
Engineering Design Data
Industrial News Buzz
Engineering Specifications
Newsletter Register
Advertise
Feedback
