Euler Number Equation and Calculator
The Euler number (Eu) is a dimensionless number used in fluid flow calculations. It expresses the relationship between a local pressure drop caused by a restriction and the kinetic energy per volume of the flow, and is used to characterize energy losses in the flow, where a perfect frictionless flow corresponds to an Euler number of 0. The inverse of the Euler number is referred to as the Ruark Number with the symbol Ru.
Eu = (Pu - Pd ) / ( ρ · v 2 )
Eu = Pressure forces / inertial forces
An alternative definition of the Euler number is given by Shah and Sekulic
Eu = (Pu - Pd ) / ( 0.5 · ρ · v 2 )
Eu = Pressure drop / dynamic head
ρ = Density of Fluid (kg/m3)
Pu = Upstream Pressure (kg/ms2)
Pd = Downstream Pressure (kg/ms2)
V = Velocity of Flow (m/s)
Eu = Euler Number (dimensionless)
  • Wikipedia
