Fanning Friction Factor in Conduits Equation and Calculator
Fanning Friction Factor for Flow in Conduits Equation and Calculator
The Fanning friction factor is not the same as the Darcy Friction factor (which is 4 times greater than the Fanning Friction factor). The formula given is very similar to the Darcy-Weisbach formula but the Hydraulic Radius of the pipe work must used, not the pipe diameter.
Published tables of Fanning friction factors are usually only applicable to the turbulent flow of water at 60º F (15.5º C).
For flow in conduits
f = 0.25 ( D / L ) [ ( Po - PL ) / ( 0.5 ρ v2) ]
D = Conduit Diameter (ft)
L = Length of conduit (ft)
Po = Pressure initial (lbs / ft2)
PL = Pressure output (lbs / ft2)
v = Flow Velocity (ft/s)
ρ = Fluid Density (g/cc)
f = Fanning Friction Factor (dimensionless)
Fanning’s friction factor (turbulent flow)
f = ( 0.0791 µ0.25 ) / ( D v ρ )0.25
µ = viscosity ( [lbf s/ft2)
0.0791 = conversion
  • Bird, R.B., Stewart, W.E. and Lightfoot, E.N. (2002). Transport Phenomena (Second Ed.). John Wiley & Sons, Chapter: 6, Page: 181.
