Pipe Straight Pipe or Large Bends Stress Calculator and Equations
Hydraulic & Pneumatics
Pipe Bending Straight Pipe or Large Bends Stress Calculator and Equations per. ASME B31.9
The nominal bending stress in a straight pipe or large radius bends due to weight or other external load calculator.
Preview: Pipe Bending Straight Pipe or Large Bends Stress Calculator
Pipe Bending Stress due to Weight or other External Loads is:
SB = M / Z
The nominal bending stress in fittings and components due to weight or other external loads is:
SB = MR / Z
Resultant intensified moment across the fitting or component. The resultant moment shall be calculated as:
Eq. 3
MR = [ ( 0.75 ii Mi )2 + ( 0.75 io Mo )2 + Mt 2 ]1/2
Eq. 4
Z = 1 / I
Eq. 5 (area moment of inertia pipe)
I = π ( D4 - d4 ) / 64
Eq. 6 (section modulus pipe)
Z = π ( D4 - d4 ) / ( 32 D )
Where
M = the bending moment across the pipe cross section, lb-in, (N-m)
Z = The pipe section modulus, in3 (m3)
ii = in-plane stress intensification factor
io = out-of-plane stress intensification factor
Mi = in-plane bending moment, lb-in. (N-m)
Mo =out-of-plane bending moment, lb-in. (N-m)
Mt = torsional moment, lb-in (N-m)
D = outer diameter, in (m)
d = inner diameter, in (m)
Pipe Data
Figure 1, Pipe Data
If a section of pipe can operate either warmer or colder than the installed temperature, both conditions to T2 may need to be examined.
Table 1, Stress Intensification Factor, i per. ASME B31.8
Description
Out of Plane
io
In-Plane
ii
Sketch
Welding elbow or pipe bend
0.75 / h2/3
0.90 / h2/3
Welding tee per
ASME B16.9 with
ro ≥ d / 8
Tc ≥ 1.5 T
3/4 io + 1/4
Welding tee per
Reinforced fabricated tee with
pad or saddle
3/4 io + 1/4
Unreinforced fabricated tee
3/4 io + 1/4
Extruded outlet
ro ≥ d / 8
Tc < 1.5
3/4 io + 1/4
Extruded outlet
ASME B31.9, Gas Transmission and Distribution Systems
