Trapezoidal Weirs Flow Formula and Calculator
Fluids Engineering and Design
Civil Engineering and Design
A trapezoidal weir is essentially a rectangular weir with a triangular weir on either side. (See Fig. 1) If the angle of the sides from the vertical is approximately 14° (i.e., 4 vertical and 1 horizontal), the weir is known as a Cipoletti weir. The discharge from the triangular ends of a Cipoletti weir approximately make up for the contractions that would reduce the flow over a rectangular weir. Therefore, no correction is theoretically necessary. This is not completely accurate, and for this reason, Cipoletti weirs are not used where great accuracy is required. The discharge is
Preview Premium Membership Calculator:" Flow Within Trapezoidal Weirs Calculator
Trapezoidal Weir
Fig. 1 - Trapezoidal Weir
Eq. 1,
Q = 2/3 Cd b (2g)0.5 H1.5
The average value of the discharge coefficient is 0.63. The discharge from a Cipoletti weir is found by using Eq. 2.
Eq. 2,
Q = 1.86 b H1.5
H = height, m
b = width of weir bottom, m
Q = Flow, m3/s
g = gravity, 9.81 m/s2
Cd = discharge coefficient (average = 0.63)
  • Civil Engineering Reference Manual, Fifteeth Edition
