Weekly Hours Worked Calculator
Weekly Hours Worked and Wages Earned Calculator
This calculator tool provides a simple way to complete a weekly timesheet for an individual or business that does not require the employee to report clock in / clock out times.
Employee Name:
Click in the provided box and typpe in your name - nothing fancy here and this is for your records.
Week of:
Click within the box and a popup should appear. Select the week which you are to record and the timesheet will be automaticall populated.
Hour and Minutes Entered
Hour's and minutes worked should be entered as h:mm, take note that the ":" separator would be entered between the hours and minutes for the correct format for calculations
Rate/Hour:
Credit :
  • Kelly B. at Engineers Edge, LLC
