Related Resources: hvac-systems
Estimated Costs of Heating Systems
Civil Engineering and Design
HVAC Design and Engineering
Estimated Seasonal Efficiencies and Annual Costs of Heating Systems
Systems
Seasonal
Efficiency
Gas Fired Gravity Vent Unit Heater
62%
Energy Efficient Unit Heater
80%
Electric Resistance Heating
100%
Steam Boiler with Steam Unit Heaters
65%-80%
Hot Water Boiler with HYD Unit Heaters
65%-80%
Oil Fired Unit Heaters
78%
Municipal Steam System
66%
INFRA Red (High Intensity)
85%
INFRA Red (Low Intensity)
87%
Direct Fired Gas Make Up Air
94%
Improvement with Power Ventilator
Added to Gas Fired Gravity Vent Unit Heater
4%
Improvement with Spark Pilot Added to Gas Fired Gravity Vent Unit Heater
1/2%-3%
Improvement with Automatic Flue Damper and
Spark Pilot Added to Gravity Vent Unit Heater
8%
Annual fuel use may be determined for a building by using one of the following formulas:
H / ( ΔT x 3413 x E ) x D x 24 x CD = KWH/YEAR
Natural Gas Heating
H / ( ΔT x 100,000 x E) x D x 24 x CD = THERMS/YEAR
Propane Gas Heating
H / ( ΔT x 21739 x E) x D x 24 x CD = POUNDS/YEAR H/( D T x 91911 x E) x D x 24 x C D = GALLONS/YEAR Oil Heating
H / ( ΔT x 140,000 x E) x D x 24 x CD = GALLONS/YEAR
ΔT = Indoor Design Minus Outdoor Design Temp.
H = Building Heat Loss
D = Annual Degree Days
E = Seasonal Efficiency (See Above)
CD = Correlation Factor CD vs. Degree-Days
Considerations Used for Corrected Values
1 - 0°F Outdoor Design (See Corrections)
2 - Slab Construction—If Basement is involved multiply final BTUH by 1.7.
3 - Flat Roof
4 - Window Area is 5% of Wall Area
5 - Air Change is .5 Per Hour.
Source
Engineering Cookbook, A Handbook for the Mechnical Designer
Second Edition
