Compressibility of a Fluid Equations and Calculator
Heat Transfer Engineering
Thermodynamics
Compressibility (also known as the coefficient of compressibility), β, is the fractional change in the volume of a fluid per unit change in pressure in a constant temperature process. Typical units are in2/lbf, ft2/lbf, 1=atm, and 1/kPa. (See Table 1.) It is the reciprocal of the bulk modulus, a quantity that is more commonly tabulated than compressibility. Equation 1 is written with a negative sign to show that volume decreases as pressure increases.
Compressibility changes only slightly with temperature. The small compressibility of liquids is typically considered to be insignificant, giving rise to the common understanding that liquids are incompressible.
Preview Premium Calculator: Compressibility of a Liqud Calculator
β = ( -ΔV / Vo ) / Δp
β
= 1 / E
Eq. 3
ΔV = Vf - Vo
Eq. 4
Δp = pf - po
E = bulk modulus, lbf/ft2, (Pa)
β = compressibility, ft2/lbf, (Pa-1)
ΔV = Change of volume, ft3, (m3)
Vf = Volume final, ft3, (m3)
Vo = Volume compressed, ft3, (m3)
Δp = Change of pressure, lbf/ft2, (Pa)
po = Pressure initial, lbf/ft2, (Pa)
pf = Pressure compressed, lbf/ft2, (Pa)
Approximate Compressibilities of Common Liquids at 1 atm
Liquid
Temperature
β (in2/lbf)
β (1/atm)
mercury
32 °F
0.028 x 10-5
0.39 x 10-5
glycerin
60°F
0.160 x 10-5
0.16 x 10-5
water
60°F
0.330 x 10-5
0.33 x 10-5
ethyl alcohol
32 °F
0.680 x 10-5
0.68 x 10-5
chloroform
32 °F
0.680 x 10-5
0.68 x 10-5
gasoline
60°F
1.0 x 10-5
1.0 x 10-5
hydrogen
20K
11 x 10-5
11 x 10-5
helium
2.1K
48 x 10-5
48 x 10-5
(Multiply 1/psi by 14.696 to obtain 1/atm.)
(Multiply in2/lbf by 0.145 to obtain 1/kPa.)
  • Victor L. Streeter, Handbook of Fluid Dynamics, Ó 1961, by McGraw-Hill Book Company.
  • Civil Engineering Reference Manual, Fifteenth Edition, Michael R. Lindeburg, PE
