Discharge Rate From Pressurized Tank Equations and Calculator
Civil Engineering Application & Design Resources
If the gas or vapor above the liquid in a tank is at gage pressure p, and the discharge is to atmospheric pressure, the head causing discharge will be
Eq. 1, SI
Head Pressure
h = z1 - z2 + p / ( ρ · g )
Eq. 1a, U.S.
Head Pressure
h = z1 - z2 + ( p / ρ ) ( gc / g ) = z1 - z2 + p / γ
Preview Discharge From Pressurized Tank Calculator
The discharge velocity can be calculated from Eq. 3 using the increased discharge head calculated from Eq. 1 & 2.
vo = Cv ( 2 · g · h )0.5
Eq. 3
V = Cd · Ao ( 2 · g · h )0.5
Where
V = volumetric flow rate, ft3/sec, m3/s
Ao = area of discharge orifice, ft2, m2
h = adjusted height / depth of head, ft, m
z1 = elevation of fluid, ft, m
z2 = elevation discharge nozzle, ft, m
g = gravitational acceleration, 32.2 ft/s2, (9.81 m/s2)
gc = gravitational acceleration, 32.2 lbf-ft/lbf-s2, (9.81 kg2/s)
ρ = fluid density lbm/ft3, kg/m3
p = pressure above liquid, lbm/ft2, kg/m2
Cv = coefficient of velocity, empirical factor that accounts for the friction and turbulence at the orifice, see Table 1
Cd = Approximate Orifice Coefficients for Turbulent Water, see Table 1
γ = specific weight of fluid lbf/ft3, N/m3
Figure 1 Discharge from a Pressurized Tank
Table 1 Approximate Orifice Coefficients for Turbulent Water
Illustration
Description
Cd
Cv
A
sharp-edged
0.62
0.98
B
round-edged
0.98
0.98
C
short tube* (fluid separates from walls)
0.61
0.61
D
sharp tube (no separation)
0.82
0.82
E
short tube with rounded entrance
0.97
0.98
F
reentrant tube, length less than one-half of pipe diameter
0.54
0.99
G r
eentrant tube, length 2 to 3 pipe diameters
0.72
0.72
H
Borda
0.51
0.98
(none)
smooth, well-tapered nozzle
0.98
0.99
*A short tube has a length less than approximately 3 diameters.
Illustrations for Table 1
Civil Engineering Reference Manual, Fourteenth Edition
Michael R. Lindeburg, PE
