Fire Sprinkler Discharge Calculator (simplified)
This calculator determines the typical discharge vs flow rate of a sprinkler head
Preview: Fire Sprinkler Discharge Calculations
Eq.1
Q = n · [ K · P1/2 ]
Where
Q = flow (gpm)
K = measure of the ease of getting water out of the orifice, related to size and shape of the orifice in units of gpm per (psi)1/2
P = pressure (psi)
n = number of sprinkler heads (identical at same pressure)
Sprinkler K Factors (typical)
Orifice Size
Name
K Factor
1/2"
Standard
5.6
17/32"
Large
8.0
5/8"
Estra Large
11.2
NFPA Standard 291, Recommended Practice for Fire Flow Testing and Marking of Hydrants.
