Engineering Design Data: Menu - excel calculators
Excel engineering calculator downloads and applications
  • Business
  • Civil Engineering
  • Design Engineering
  • Electrical Electronics Excel Calculators
  • Fluids Engineering
  • Heat Transfer Engineering Design
  • HVAC Heating Ventilation Air Conditioning
  • Manufacturing
  • Welding Design and Engineering
  • Prev Page | Next Page
    Pages: 1 2 [3] 4 5 6 >>
    Bolted Connections Bolt Thread Pull Through
    Simple method for bolt thread pull through.
    Bolted Connections Effects on Plates
    Bolted Connections Effects on Plates: Various methods of assessing the effect of bolts on a plate.
    Bolted Connections Bolt Bending
    Bolted Connections Bolt Bending: Several methods for calculating the bending moment in a bolt.
    Bolted Connections Combined Shear And Tension
    Bolted Connections Combined Shear And Tension: Description: Interaction of shear and tension on the shank of a bolt.
    Beam in a Socket Calculator
    Beam in a Socket Calculator. Beam in a Socket method – assumes a perfect fit between pin and socket.
    Torsion Properties – Irregular Sections
    Torsion Properties – Irregular Sections. Stress Analysis Manual, Air Force Flight Dynamics Laboratory, Wright Patterson AFB, OH, Oct 1986
    Torsion Properties Regular Sections
    Torsion properties of Regular Cross-Sections.
    Airbus and Boeing Seat Track Specifications
    Section properties of common Airbus and Boeing Seat Tracks
    Section Properties Shapes
    Section properties of various common regular shapes. References: Non Specific, General Method
    Aluminum Material Data Plastic Bending
    Aluminum Material Data Plastic Bending. Cozzone Method using Fty and Ftu as the reference stresses deriving the area of the trapezoidal stress distribution.
    Disclaimer
