Sealing Flanges with Gaskets Bolt Torque Requirements Calculator
Pressure Vessel Pipes Design Engineering ASME
Bolt Torque Required for Sealing Flanges with Gaskets and Internal Pressure
Preview Bolt Torque Required for Sealing Flanges with Gaskets Calculator (Premium Membership required for calculator)
Equivalent Pressure
P c = 16 M π G 3 + 4 P r π G 2 + P
Hydrostatic end force, H, lb
H = π G 2 P c 4
Total joint-contact-surface compression load, Hp, lb
Eq. 3
H p = 2 b π G m P c
Minimum required bolt load for gasket seating, Wm2, lb.
Eq. 4
W m 2 = π b G y
Actual joint area contact for gasket, Ag, in2
Eq. 5
A g = 2 π b G
Decreasing compression force in gasket, ΔF, lb
Eq. 6
Δ F = H 1 + A b E b t g A g E g l b
Initial required tightening force (tension), Fbo, lb.
Eq. 7
F b o = H p + Δ F
Total tightening force required to seal joint, W, lb.
Eq. 8
W = greater of Fbo or Wm2
Required torque, T, ft-lb
Eq. 9
T = K W d m 12 n
Pe = equivalent pressure including external loads, psi
M = external bending moment, in.-lb
G = avaerage diameter at location of gasket load reaction, in.
Pr = radial load, lb
P = internal pressure, psi
b = effective gasket seating width (diameter), in.
m = gasket factor
Wm2 = required bolt load, gasket seating, lb
y = gasket unit seating load, psi
Ag = actual joint-contact area of gasket, in.2
ΔF = Decreasing compression force in gasket, lb
H = total hydrostatic end force, lb
Ab = cross-sectional area of bolts, in.2
Eb = modulus of elasticity of bolting material at temperature, psi
tg = thickness of gasket, in.
lb =
Hp = total joint-contact surface compression load, lb
Fbo = = initial tightening force, Ib
K = total friction factor between bolt / nut and nut / flange face
W = total tightening force, lb
dm = pitch diameter of threads, in
n = number of bolts
Friction factor (typical)
Lubricated = 0.075-0.15
Nonlubricated = 0.15-0.25
Figure1 Flange and joint details.
Table 1, Torque Required in ft-lb to Produce the Following Bolt Stress
Bolt Size 15 ksi 30 ksi 45 ksi 60 ksi
1/2-13
15 30 45 60
5/8-11
30 60 90 120
3/4-10 50 100 150 200
7/8-9 80 160 240 320
1-8 123 245 368 490
1-1/8 - 8 195 390 533 710
1-1/4 - 8 273 500 750 1000
1-3/8 - 8 365 680 1020 1360
1-1/2 - 8 437 800 1200 1600
1-5/8 - 8 600 110 1650 2200
1-3/4 - 8 775 1500 2250 3000
1-7/8 - 8 1050 2000 3000 400
2-8 1125 2200 3300 4400
2-1/4 - 8 - 3180 4770 6360
2-1/2 = 8 - 4400 6600 8800
2-3/4 - 8 - 5920 8880 11840
3 - 8 - 7720 11580 15440
Notes:
1. Bolted joints in high-pressure systems require an initial preload to prevent the joint from leaking. The loads which tend to open the joint are:
a. Internal pressure.
b. Thermal bending moment.
c. Dead load bending moment.
2. Either stud tensioners or torque wrenches are used for prestressing bolts to the required stress for gasket seating. Stud tensioners are by far the most accurate. Stud tension achieved by torquing the nut is affected by many variables and may vary from 10% to 100% of calculated values. The following are the major variables affecting tension achieved by torquing:
a. Class of fit of nut and stud.
b. Burrs.
c. Lubrication.
d. Grit, chips, and dirt in threads of bolts or nuts.
e. Nicks.
f. The relative condition of the seating surface on the 3. Adequate lubrication should be used. Nonlubricated bolting has an efficiency of about 50% of a well-lubricated bolt. For standard applications, a heavy graphite and oil mixture works well. For high temperature service (500'F to 1000"F), a high temperature thread compound may be used.
4. The stiffness of the bolt is only 1/3 to 1/5 that of the joint. Thus, for an equal change in deformation, the change of the load in the bolt must be only 1/3 to 1/5 of the change in the load of the joint.
5. Joints almost always relax after they have first been tightened. Relaxation of 10% to 20% of the initial preload is not uncommon. Thus an additional preload of quantity F is required to compensate for this “relaxing” of the joint.
Pressure Design Manual, Third Edition, Dennis Moss 2004
