Engineering Design Data: Menu - excel calculators
Excel engineering calculator downloads and applications
  • Business
  • Civil Engineering
  • Design Engineering
  • Electrical Electronics Excel Calculators
  • Manufacturing
  • Prev Page | Next Page
    Pages: << 4 5 6 [7] 8 9
    Periodic Conduction in a Semi-Infinite Body Calculator
    Periodic Conduction in a Semi-Infinite Body Excel Calculator. Animates the analytical solution for transient conduction in a semi-infinite body subject to a periodically varying temperature at the exposed face.
    Two-Dimensional, Steady-State Conduction Excel Spread Sheet Calculator
    evaluates the analytical solution for steady-state conduction in a unit square with one boundary held at a different temperature than the other three and returns a raised contour plot of the results.
    Internal-Flow Convection Correlations
    This workbook computes the Nusselt number for forced convection in a circular pipe as a function of the Reynolds (based on diameter) and Prandtl numbers (and where appropriate one or two other parameters).
    Competitive Semiconductor Manufacturing (CSM) Program Excel Spreadsheet
    This Excel workbook provides spreadsheet models for calculating revenues and costs of wafer fabrication.
    TEEP and OEE Comparison Excel Spreadsheet
    This spreadsheet is a tool to record and compare your TEEP and OEE values.
    Program Management Maintenance ROI Template
    This excel spreadsheet is an excellent template for determining the return on investment (ROI) for maintenance activities.
    Six Sigma Template & Calculator Excel Spread Sheet
    Breakthrough Strategy, SS Project Plan, Project Action Plan, CTQ Template, SIPOC, Process Analysis, Fishbone and more
    Lean Implementation Worksheet
    This excel calculator and worksheet provides a template for estimating the payback from a lean implementation.
    Bevel Gears Tooth Strength AGMA
    This excel calculator will estimate bevel gear tooth strength.
    Column Bucking Load Excel Calculator
    Column Bucking Load Excel Calculator per Young, ROARK'S FORMULAS FOR STRESS & STRAIN, Sixth Edition, 1989, pp 487-492.
    © Copyright 2000 - 2017, by Engineers Edge, LLC All rights reserved.
    Disclaimer
