Design Engineering and Manufacturing Perspective from Europe and Asia
Member Sign in | Member Control Panel
Signup
The following resources require a paid premium monthly or annual membership for access.
- Should you find any errors omissions broken links, please let us know - Feedback
Open:
Part 1 Design Engineering and Manufacture Perspective from Europe and Asia
Part 2 Design Engineering and Manufacture Perspective from Europe and Asia
Part 3 Design Engineering and Manufacture Perspective from Europe and Asia
Part 4 Design Engineering and Manufacture Perspective from Europe and Asia
Abstract:
A primary objective of knowledge engineering is to facilitate the application of knowledge arising from product design and the planning of the manufacturing process for new and modified products. Knowledge is an expensive and valuable commodity so the development of methods for its capture, representation and application are of considerable importance. The emphasis of the research described in this paper is on the re-use of knowledge for the creation of product variants. This implementation of 'predictive design' represents the very significant move from standard parts to standard knowledge constructs. Standard parts can be used in any application that requires a defined function where the shape and properties do not need to be altered. However, standard knowledge constructs can provide parts that can be used wherever the function is required. The Process Specification Language (PSL) provides one possible way of achieving this aim and is briefly outlined. A complementary method using 'knowledge fragments' for Failure Modes and Effects Analysis (FMEA) applied to electronic products is also described.
Key words: Knowledge Engineering, Predictive Design, Process Specification Language, FMEA.
Table of Contents
PART 1
KNOWLEDGE INTENSIVE METHODOLOGIES AND TOOLS SUPPORTING ENGINEERING DESIGN AND MANUFACTURE ...... 1
KNOWLEDGE ENGINEERING IN PRODUCT AND PROCESS DESIGN
Keith Case ............................................................................................ 3
A PROPOSAL OF DESIGN VISION FOR ARTIFACT DESIGN AND PRODUCTION IN THE 21ST CENTURY
Teruyuki Monnai, Eiji Arai, Juhachi Oda, Tetsuo Tomiyama and Akihiro Hotta .... .................................................................................. 19
RESEARCH OF VIRTUAL PROTOTYPING FOR AUTO-BODY SHEET METAL ASSEMBLY
Wenfeng Zhu, Xinmin Lai and Zhongqin Lin ..................................... 31
A RETRlEV AL AGENT ARCHITECTURE FOR RAPID PRODUCT DEVELOPMENT
Stavros Dalakakis, Emil A. Stoyanov and Dieter Roller .................... 41
COMPUTER-AIDED TECHNIQUES IN MANUFACTURING OF LARGE HYDRO TURBINE'S BLADES
Xi-De Lai, Ci-Chang Chen and Qing-Gang Li .................................. 59
USING CONTEXT KNOLEDGE BASED REASONING TO SUPPORT FUNCTIONAL DESIGN
Fayyaz Rehman andXiu-Tian Yan ..................................................... 69
VIRTUAL PRODUCT DEVELOPMENT
Wenli Zhang, Dieter Roller, Wenlin Chen and Hongfu Zuo .............. 79
GRAPH BASED REPRESENT A TION IN DESIGN OF
MULTIFUNCTIONAL STRUCTURE
Yuemin Hou, Linhong Ji and Dewen Jin ............................................ 89
PATCH UNIT METHOD FOR CAD SURF ACE MODELS
Xingbo Wang and Jin-Long Shi ......................................................... 99
PROACTIVE SUPPORT FOR PRODUCT CONCEPTUAL DESIGN INCORPORATING MANUFACTURING SYSTEM CONSIDERATIONS
Zifang Wu, Xiu-Tian Yan, Jianhua Yang and Xiansheng Qin .......... 115
AUTOMATED GENERATION OF DIMENSION CHAINS FOR AUTOBODY DIMENSIONAL QUALITY EVALUATION ................................... .
Jiangqi Zhou, Guanlong Chen, Xinmin Lai and Zhongqin Lin ........ 125
GENETIC ALGORITHM-BASED SCHEME GENERATION FOR MECHANICAL PRODUCTS IN CONCEPTUAL DESIGN
Rui-Feng Bo, Hong-Zhong Huang, Ying-Kui Gu and Li-Hua Xue .. 135
RESEARCH ON PRODUCT MODELING TECHNOLOGY FOR DISASSEMBL Y
Weixiang Guo, Guangfu Liu, Zhifeng Liu and Haihong Huang ...... 145
MUL TIOBJECTIVE OPTIMIZATION-BASED MANUF ACTURABILITY EVALUATION FOR PART STRUCTURE
Shan Jiang, Yuxin Wang and Yiming yang ...................................... 155
A VIRTUAL PRODUCT FAMILY TO SUPPORT DESIGN FOR CUSTOMERS
Yan Li, Shujuan Li and Shaokun Wei ............................................... 165
THE RESEARCH ON INTEGRA TED SYSTEM OF MECHANICAL PRODUCT INTELLIGENT DESIGN AND MANAGEMENT DECISION
SUPPORT IN CE ENVIRONMENT
JingXin Chen, Jing Xu, Hong Li, JiPing Zhou and Lan Cai... ......... 175
A STUDY OF DECISION-MAKING ON PROCESS METHODS SELECTION BASED ON GA
Qing-Jun Lee and Tan-Cheng Xie .................................................... 187
CAD MODELING OF STRAIGHT BEVEL GEARS
Wei Wei, Keke Zhu, Luling An and Laishui Zhou ............................ 195
THE RESEARCH OF A NEW GEOMETRIC CONSTRAINT SOLVER
Chunhong Cao, Wei Fu and Wenhui Li .......................................... 205
MODELING OF COM-BASED VIRTUAL FMS .......................................... .
Guo-Fu Ding, Kai-Yin Yan, Zhao-Xue Gao and Yi-Shen Zou ......... 215
PART 2
DESIGN EDUCATION AND COLLABORATIVE WORKING IN DESIGN AND MANUFACTURE .......................................................... 223
EDUCATING THE GLOBAL DESIGNER
William J Ion, Andrew Wodehouse, Neal Juster, Hilary Grierson and
Angela Stone ..................................................................................... 225
WEB EDUCATION PORTAL FOR THE TEACHING OF MECHANICAL DESIGN AND MANUFACTURING
Didier Remond, Alexandre Toumine, Benoit Eynard, Nadege Troussier, Alain Daidie, Jean-Pierre Devaujany, Samuel Gomes and
Lionel Roucoules .............................................................................. 237
FRAMEWORK FOR MECHATRONICS SYSTEMS DESIGN
Lars Hein .......................................................................................... 251
COLLABORATIVE AND REMOTE DESIGN OF MECHATRONIC PRODUCTS
Benoit Eynard and Samuel Gomes ................................................... 261
COMPARISONS OF CHINA'S EDUCATION IN SCIENCE AND TECHNOLOGY TO THE DEVELOPED WORLD
Xincai Tan and Xiu- Tian Yan ........................................................... 271
CASE STUDY OF COLLABORATIVE KNOWLEDGE MANAGEMENT IN THE EARLY PHASES OF PRODUCT DEVELOPMENT
James Gao, Hayder Aziz, Paul Maropoulos and Wai M Cheung .... 283
A DEVELOPMENT ON MANUFACTURING INFORMATION
COMMUNICATION IN AGILE MANUFACTURING WITH STEP AND
XML
Xiaoli Qiu and Hong Yi .................................................................... 297
WEBCAPP: COLLABORATIVE INTELLIGENT PROCESS PLANNING SYSTEM
Jitender Rai and S.S.Pande ............................................................ 307
COORDINATION COMPONENT BASED ON PETRI NET FOR COLLABORATIVE DESIGN
Feng Zhou, Hong-Zhong Huang and Xu Zu .................................... 317
DYNAMIC DATA EXCHANGE IN THE COLLABORATIVE DESIGN BASED ON INTERNET ENVIRONMENT
Tianhong Luo, Xiaoan Chen, Lihong Lin, Bing Zhang and Zhihong
Xian .................................................................................................. 327
THE IMPACT OF DOCUMENTATION AND REFLECTION ON STUDENT LEARNING IN ENGINEERING DESIGN
A. Wodehouse, H Grierson, WJ. Ion, N. Juster and A.S. Stone ...... 337
PART 3
MATERIALS DESIGN AND THEIR MANUFACTURE , MANUFACTURE AND MANUFACTURING AUTOMATION ........ 347
ALUMINOTHERMIC REDUCTION OF ZIRCONIA
Xiaoli Zhe, C A Dioka and A Hendry ............................................... 351
MODELING THE OXIDATION AND CORROSION BEHAVIOR OF 3D CARBON FIBER REINFORCED SIC MATRIX COMPOSITES FROM
400 TO 1500 DEGREES C
Qingfeng Zeng, Laifei Cheng, Litong Zhang, Xingang Luan, Xiaowei
Yin and Yongdong Xu .................................................... ................... 363
DIRECTIONAL BEAM BASED APPROACH APPLIED TO THE CHOICE OF MACHINING DIRECTION FOR A SCULPTURED PART
Yann Quinsat, Laurent Sabourin and Grigore Gogu ....................... 373
A DISTRIBUTED PRODUCTION CONTROL SYSTEM ON A COMPONENT-BASED SOFTWARE DEVELOPMENT AND
OPERATION FRAMEWORK
Hiroyki Sawada, Norio Matsuki and Hitoshi Tokunaga .................. 383
JOB-SHOP SCHEDULING USING IMMUNE ALGORITHM BASED ON DYNAMIC EVALUATION
Jianjun Yu, Shudong Sun and Ganggang Niu .................................. 393
PREVENTIVE MAINTENANCE AND JOINT BUFFER INVENTORY FOR PARALLEL MACHINES
Valerio Boschian, Nidhal Rezg and Gilles Cormier ........................ 405
DESIGN AS PRODUCTIVE SCIENCE
Yuemin Hou, Linghong Ji and Dewen Jin ........................................ 417
OPTIMIZATION OF CUTTING PARAMETERS FOR PERIPHERAL MILLING BASED ON MACHINING STABILITY
Yong Chen and Xiong-Wei Liu ......................................................... 427
A REMOTE TECHNIQUE SUPPORT SYSTEM OF ENGINEERING
EQUIPMENT
Huan-Liang Li, Qi Zhang, Cheng-Xian Yang and Song-Hui Guo ... 439
METHODS FOR RECONFIGURING MULTI-AGENT AND SELECTING SENSOR IN RECONFIGURING MONITORING SYSTEM BASED ON
KNOWLEDGE
Youping Fan, Yunping Chen and Wansheng Sun ............................. 449
REAL-TIME QUALITY MONITORING TECHNOLOGY FOR POWDER COMPACTING PROCESS
Ge-Wei Chen .................................................................................... 459
APPLYING GSPN THEORY ON PERFORMANCE ANALYSIS OF THE SERIAL AND PARALLEL PRODUCTION SYSTEMS
Jianhua Gao, Xudong Hu and Ruqing yang .................................... 469
OPTIMIZATION DESIGN OF HYDRAULIC SERVO ACTUATORS WITH 3-D.O.F. AND MOTION DECOUPLING
Xinglong Zhu, Jiping Zhou and Jianhua Zhou ................................. 479
A FRAMEWORK FOR CIGARETTE SUPPLY CHAIN IN THE MONOPOLY ENVIRONMENT
Tianfei Li and Linyan Sun ................................................................ 489
THE OPTIMIZATION APPROACH OF ASSEMBLY SEQUENCE BASED ON GENETIC ALGORITHM
Chun-Shu Li, Li-Min Dai and Li-Min Wang .................................... 499
THE APPLICATION OF THE FUZZY EVALUATION IN LASER MICRO-MANUFACTURING SYSTEM
Hui-Lai Sun, Shu-Zhong Lin, Jin-Gang Wang, Hong-Lai Li and XM
Liu ...................................................... .............................................. 507
STUDY ON CONCURRENT DEIGN IN FORMING DIE FOR ITS LIFE
F eng Ni and Jianping Lin ................................................................. 515
STUDY ON THE ARCHITECTURE OF RECONFIGURABLE ASSEMBLY SYSTEM
Fanli Meng, Xuemei Huang, Dalong Tan and Yuechao Wang ....... 521
COMBINE AGENT AND HOLON APPROACH FOR MANUFACTURING SCHEDULING IN CAPP!PPC
Shujuan Li and Yan Li ...................................................................... 533
AN ALGORITHM OF TOOL PATH GENERATION FOR PARTS WITH REGULAR FEATURES
Luling An, Laishui Zhou, Wei Wei and Rurong Zhou ...................... 543
SIMULATION OF THE MACHINING ERROR OF CNC GEAR SHAPER BASED ON MULTI-BODY SYSTEM THEORY
Shuxin Wang, Yanzheng Li, and Jintian Yun .................................... 551
MULTI-AGENT SYSTEMS FOR CRACKING SUPPLY CHAIN BULLWHIP EFFECT
Oboulhas Tsahat Conrad Onesime, Xiaofei Xu, Dechen Zhan and
Kimutai Kimeli ................................................................................. 559
A 3D DIGITIZING MEASUREMENT SYSTEM BASED ON NOVEL PASSIVE ROBOT
Li-Bin Du, Xiao-Hui Gao, Hao Wang, Jing-Dong Zhao and Hong Liu
.......................................................................................................... 569
RESEARCH OF REMOTE CONTROL SYSTEM BASED ON FIELD BUS
AND INTERNET
Tan-Cheng Xie and Ke Hu ............................................................... 577
PART 4
PRODUCT DEVELOPMENT AND DESIGN PRACTICE ................ 585
INTEGRATION OF PRODUCT - PROCESS - ORGANISATION FOR ADVANCED ENGINEERING DESIGN
Philippe Girard and Benoit Eynard ................................................. 587
A UNI-AXIAL TEST RIG DESIGN APPROACH FOR DEFORMATION ANALYSIS OF FLEXIBLE PARTS DUE TO LOCATION TYPE TOLERANCE IN ASSEMBLY
Irfan A Manarvi and NP Juster ................................................ ....... 599
GENERATING MECHANISM AND EXPERIMENTAL STUDY ON IMPACTING WATER JET BY MODULATION OF CHAOS
Xin-Min Zhang and Xiong Duan ...................................................... 609
DESIGN ANALYSIS AND MANUF ACTUIRNG PLANNING USING ISO 010303 STEP AP224
Rohit Sharma and James X Gao .... ................................................. 621
STUDY ON QUALITY EVALUATION TECHNIQUE FOR RESEARCHING AND DEVELOPING SYSTEM OF MECHANICAL
PRODUCTS
Qi Zhang, Cheng-Xian Yang, Huan-Liang Li and Wei Sun ............. 635
CONFIGURATION MANAGEMENT USING STANDARD TOOLS ......... .
Marian Mdina and Dieter Roller .................................................... 645
THE APPLICATION OF SSE TECHNIQUE IN FAST RECONSTRUCTION
Haipeng Mao, Dinghua Zhang, Liang Liang, Juan Gu and Qingsheng
Wang ................................................................................................ 659
CALCULATING ELASTIC MODULUS OF BOTH ENDS FIXED POL YSILICON MICROBEAMS WITH TRAPEZOIDAL CROSS SECTION
Guangping Han, Kai Liu and Xiuhong Wang ................................. 669
A WEB-BASED OPTIMIZATION FOR FUNCTION SYNTHESIS OF PLANAR LINKAGE
Lei Song and Xin Wu .................................................... .................... 677
OPTIMAL DESIGN OF THE FASTENER'S MINIMUM COST
Mingyuan Wu and Wei yang .................................................... ........ 687
STUDY OF HELICAL OIL GROOVED JOURNAL BEARING AND LASER PROCESSING FOR THE GROOVES
Hong-Lai Li, Shu-Zhong Lin, Hui-Lai Sun and Jin-Gang Wang ..... 695
AN INTEGRA TED PRODUCT AND PROCESS DEVELOPMENT MODEL SUPPORTING ENTIRE LIFE CYCLE
Ying- Kui Gu and Hong-Zhong Huang .. .......................................... 703
TOOTH CONTACT ANALYSIS OF TI WORM GEARING CONSIDERING BOUNDARY CONDITION
Luqian Duan, Yuehai Sun and Qingzhen Bi. ..... ............................... 713
THE STUDY AND DEVELOPMENT OF THE PACKING SYSTEM OF TWO DIMENSIONAL IRREGULAR POLYGONS
Guolin Duan, Caihong Wang and Jin Cai ....................................... 723
INVENTIVE DESIGN OF CONTINGENT ANTENNA WITH TRIZ
Tuan-Jie Li and Jian-Yuan Jia ......................................................... 733
ANALYSIS OF COMPACTION PROCESS BETWEEN IMPACT COMPACTING MACHINE AND ROADBED
Qian Liu, Jin-Gang Wang, Gen-Qun Cui, Yi-Min Wu and Zhi-Ge Zhou
.......................................................................................................... 743
RESEARCH ON MODELING FOR RECYCLING STRATEGY OF WASTE PRODUCTS
Haihong Huang, ZhiJeng Liu, Shuwang Wang, Guangfu Liu and
Weixiang Guo ................................................... ................................ 753
DEVELOPMENT OF COMPUTER AUTO COLOR MATCHING DESIGN SYSTEM FOR TOOTH REPARATION
Dan Jiang, Gaofing Wu and Lancheng Wang .................................. 763
STRUCTURE DESIGN FOR AUTOMATIC CONVEYING
Yinghou Lou, Yanan Jiang and JinLiu ............................................. 771
AUTHORS INDEX .................................................................................. 779
