Related Resources: 3D Printing
3D Printing with PLA Filament
3D Printing Design and Engineering
Plastics Engineering and Design
3D Printing Filament Store
Polylactide (PLA) 3D Printer Filament Specifications:
Description: Polylactide, also known as Polylactic Acid is a biodegradable thermoplastic printer filament. PLA is synthesized from organic sugars and is the most common material used for 3D printing due to its eco-friendliness and ease of use. PLA has several desirable properties in 3D printing, such as low melting point and glass transition temperature. Additionally PLA exhibits minimal distortions during the liquid to solidification process resulting in less warping of the printed part.
PLA is recommended 3D printing filaments for novices and applications where the end item will not be exposed to extreme temperatures
PLA Applications:
- General purpose 3D printing
- Fine detail parts
- Cosmetic parts
PLA 3D Printer Filament and Settings:
- Extruder printing temperature 185 - 210°C ,
- Print location cooling enabled ,
- Heated Bed capable printer temperature 60 - 70°C ,
- Printer travel speed 30 to 200mm/sec,
- Bed adhesion: PEI printing surface, Blue painters tape (thin), PVA based glue
Engineers Edge General 3D Printing Recommendations:
Normal Printing Quality:
- Print Speed: 45 mm/s
- Printing Temperature: 205 °C
- Bed Temperature: 60°C
- Ambient Printer Temperature: 20 - 27 °C
- Layer Height: 0.25 mm
- Shell Thickness: 1.0 mm
- Bottom/Top Thickness: 1.0mm
- Fill Density: 20% Diamond
High Printing Quality:
- Layer Height: 0.14 mm
- Bottom/Top Thickness: 1.12 mm
Fast Printing Low Quality:
- Layer Height: 0.38 mm
- Bottom/Top Thickness: 0.76mm
Mechanical Properties:
Mechanical Properties (Typical) | Testing Method | |
Tensile Strength ar Break psi | 770 |
ASTM D638
Yield Strength, psi | 8700 |
ASTM D638
Tensile Elongation, % | 6.0 |
ASTM D638
Heat Distorsion Temp | 55°C (131°F) |
Nominal Sizes | 1.75, 2.90 |
Relative Elongation % | 122 - 140 |
O.D. Tolerance, mm | ± 0.08 |
Circularity (Roundness) | < 0.05 |
Storage:
PLA should be stored in a clean dry location, below 50°C. Filament should be protected from dust ad other contaminants. When storing 3D printing PLA for extended periods of time the filament should be placed within a sealed plastic back along with moisture absorbing silica. Also, see Storing PLA and ABS 3D Printer Filament .
Safety and handling information:
PLA is non-toxic. It can be handled as any normal material.
- Learning to Get Great 3D Prints
- 3D Printing with ABS Filament
- 3D Additive Printing Manufacturing | 3D Additive Printing Manufacturing
- Storing ABS and PLA 3D Printing Filament
- 3D Printing for Superalloys
- 3D Printing Manufacturing of Aerospace Alloys
- Mostly 3D Printed (Plastic) Router CNC built in house
