Bearings, Design, Friction, Lubrication
Bearing Engineering and Design Resources
Bearings, Design, Friction, Lubrication - Bearing Materials
Third Edition, Revised and Enlarged
Industrial Press
1912
56 pages
This resource requires a Membership (basic - free)
Open and view: Bearings, Design, Friction, Lubrication - Bearing Materials
Preface:
In the second edition of this Reference Series Book, a chapter on the principles of thrust bearings was introduced, together with a very important chapter on friction and lubrication of bearings. An additional chapter on bearing metals was also included in that edition. In order to provide space for this material, the chapter on ball bearings which was contained in the first edition, was eliminated. This chapter, together with a considerable amount of additional matter on the same subject, is included in MACHINERY'S Reference Book, No. 56, "Ball Bearings."
Introduction, Chapter 1:
The design of journals, pins, and bearings of all kinds is one of the most important problems connected with machine construction. It is a subject upon which we have a large amount of data, but, unfortunately, they are very conflicting. The results obtained from the rules given by different mechanical writers will be found to differ by GO per cent or more. Many of our best modern engines have been designed in defiance of the generally accepted rules on this subject, and many other engines, when provided with what were thought to be very liberal bearing surfaces have proved unsatisfactory. This confusion has largely been the result of a misconception of the actual running conditions of a bearing.
Content:
The Design of Bearings, by FORREST E. CARDULLO - 3
Causes of Hot Bearings, by E. KISTINGER - 15
Thrust Bearings - 21
Friction and Lubrication - 25
Bearing Metals, by JOSEPH H. HART - 35
Alloys for Bearings - ... 40
Friction of Roller Bearings, by C. H. BENJAMIN - - 45
Apparatus for Testing: Boiler Bearings
