Cathodic Inspection and Testing For Piping |
Cathodic Inspection and Testing For Piping - cathodic protection or other corrosion control measures can be affirmed by visual observation, measurements of pipe wall thickness, or by use of internal inspection devices. |
Heat Treatment Iron and Steel |
Heat Treatment and Properties of Iron and Steel. Introduction, Properties of iron, Alloys of iron and carbon, Decomposition of ausenite, Heat treatment of steels, Hardenability.. |
Design Rules Vacuum Chambers |
Producing a vacuum chamber means defining the boundary conditions (inner and outer envelopes, operational constraints, etc.), choosing the material, designing the parts, manufacturing and assembling these parts together and putting them under vacuum. This paper gives the methodology, methods and hints for designing vacuum chambers. |
Details Machine Tool Design No. 14 |
Details of Machine Tool Design No. 14, Elementary Principles of Cone Pulleys and Belts, Cone Pulley Radii, Strength of Countershafts, Tumbler Gear Design... |
Design for Pipe and Tube Forming |
Basic Engineering Considerations, Application Requirements, Ductility of Material, Radius of Bends, Thickness of Material, Geometry, Common Bend Types |
Elements of Metric Gear Design |
This document presents the Elements of Metric Gear Design.Gears are some of the most important elements used in machinery. There are few mechanical devices that do not have the need to transmit power and motion between rotating shafts. Gears not only do this most satisfactorily, but can do so with uniform motion and reliability. |
