Related Resources: Software Applications
Involute Spur Gear Generation Application and Calculator
Involute Spur Gear Generation Python Application and Calculator
This is a Involute spur gear generation library.
Premium Membership Required
Download: Stress Strain Curve plotting Python Calculator
Features
- Involute profile of adjustable accuracy.
- Gear root filleting.
- Internal ring gearing option.
- Adjustable module, tooth number, and pressure angle (14.5 and 20 tested)
- Adjustable backlash, to allow for manufacturing tolerances.
Editing for output
Check out example_usage.py and the comments within involute_gear.py for usage details.
Figure 1 - Generated Involute spur gear
Source
Python code - This application requires knowledge of Python installation and code execution as follows
Construct an involute gear, ready for generation using one of the generation methods.
:param module: The 'module' of the gear. (Diameter / Teeth)
:param teeth: How many teeth in the desired gear.
:param pressure_angle_deg: The pressure angle of the gear in DEGREES.
:param fillet: The radius of the fillet connecting a tooth to the root circle. NOT WORKING in ring gear.
:param backlash: The circumfrential play between teeth, if meshed with another gear of the same backlash held stationary
:param max_steps: Maximum steps allowed to generate the involute profile. Higher is more accurate.
:param arc_step_size: The step size used for generating arcs.
:param ring: True if this is a ring (internal) gear, otherwise False.
- Spur Gear Generator with Download Spur Gear Generator is unitless: you may choose inches, cm or millimeters when importing your DXF file as you will have the same value for D/P as it is set above or as imported (SI or imperial units).
- AGMA Contact Stress Number Formula for Gear Tooth Equation and Calculator Per standard ANSI/AGMA D04 Fundamental Rating Factors and Calculation Methods for Involute Spur and Helical Gear Teeth:
- AGMA Gear Tooth Bending Stress Formula and Calculator Per standard ANSI/AGMA D04 Fundamental Rating Factors and Calculation Methods for Involute Spur and Helical Gear Teeth:
- Involute Spline Engineering Drawing Data When defining engineering design data on an engineering drawing for involute splines, uniform and consistent specifications.
- Involute Spline per ANSI B92.1 Equations These splines or multiple keys are similar in form to internal and external involute gears.
- Involute Spline and Serration Universal Design Calculator Involute Spline and Serration Design Calculator for the following engineering standards:
- Involute Gear Design Equations and Calculator Equations and engineering design calculator to determine critical design dimensions and features for an involute gear
- Spline Engineering Design Formula ISO 5480standard applies to splined connections with involute splines based on reference diameters for connecting hubs and shafts..
- Gear Pitch Conversions The following charts convert gear pitch dimensional data to the following: Diametral Pitch Module Circular Pitch
- Gear and Tooth Component Illustration A gear or cogwheel is a rotating machine part having cut teeth, or cogs, which mesh with another toothed part in order to transmit torque.
- Gear Equations, Calculators and Formula Spur Gear design formula for geometry, pitch, tooth clearance and critical functional data.
- Gear Material Steels for Industrial Gearing Gear engineering materials are typical steel used within industrial applications.
- Gear Terminology and Definitions Backlash is the amount by which the width of a tooth space exceeds the thickness of the engaging tooth on the pitch circles.
