Critical Hall Parameter s parameter Formulae and Calculator
Instrumentation, Electronics and Control Sensors
Critical Hall "s" parameter Equations and Calculator
The electrothermal instability (also known as the ionization instability) is a magnetohydrodynamic ( MHD ) instability appearing in magnetized non-thermal plasmas used in MHD converters. This instability is a turbulence of the electron gas in a non-equilibrium plasma (i.e. where the electron temperature Te is greatly higher than the overall gas temperature Tg). It arises when a magnetic field powerful enough is applied in such a plasma, reaching a critical Hall parameter βcr.
This formula calculates the 's' parameter of the Critical Hall parameter.
Use this formula in combination with the other available “Critical Hall parameter” formulas.
s = ( 2 · k · Te2 ) / ( Ei · ( Te - Tg )· 1 / [ 1 + ( 3 k Te ) / ( 2 Ei ) ]
Where :
s = 's' parameter (see : "Critical Hall parameter" formulas) (dimensionless)
k = Boltzmann constant ( 1.3806488 x 10-23 J/K)
Te = The electron temperature (K)
Ei = The ionization energy (1.609 x 10-19 J) (J)
Tg = The overall gas temperature (K)
Wikipedia, "Critical Hall parameter"
