Sheet Metal Clearance Width Swaging Clearance Width Swaging Equations and Calculator
Sheet Metal Design and Engineering
Sheet Metal Two Flanges Overlap Clearance Width Swaging Tool Design Equations and Calculator.
Flange Width (FM) = SB + PT + EMT + C / 2 + EM
or
Flange Width (FM) = SB + PT + S / 2 + EM
** Whichever is largest **
FM = Flange Width (in, mm),
EMT = Edge Margin Tolerance: Typical (.05 in, 1.27 mm),
C = Fastener Head Diameter (in, mm),
SB = Setback Radius on Outside Wall (in, mm),
PT = Tolerance of Part Radius (in, mm),
S = Outside Diameter of Swaging Tool Or Equivalent (in, mm),
EM = Flange Edge to Fastener Center (in, mm)
