Split Ring Planetary Gearbox Python Script Application
Gears Engineering and Design
Split Ring Planetary Gearbox Python Script Application and Calculator
This is a collection of Python scripts for designing a Split Ring Planetary Gearbox.
This is a really simply python script that helps design split-ring planetary compound gearboxes. The _gui.py script runs a Tkinter gui that allows for easy use and exports your desired number of solutions to a .csv file
NOTE:
Refunds are not awarded after Python files have been downloaded - review your membership agreement for details.
​Units (if utilized) utilized within calculators are either SI or Imperial (some enable both SI and Imperial) and member (you) are responsible for conversions. Ensure that you verify units utilized in excel application meet your requirements before downloading.
Download: Split Ring Planetary Gearbox Python Calculators
Helps generate planetary gear combinations:
  • number of teeth for sun, planets, outer ring
  • output gear ratio
  • module/sizes
Only works with split-ring compound planetary gears that are driven via first stage sun gear and output through second/last stage's outer ring, AKA split-ring
Example output excel data file - Split Ring Planetary Gearbox
Figure 1 Gear Input data GUI
Gear Input data GUI
Source
Support:
  • Engineers Edge has tested the basic functions and operation of this application using Python 3.11.9 and supporting modules.
  • THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
