Engineering Design Data: Menu - excel calculators > Fluids Engineering
Fluids, Hydraulics Excel Applications
Prev Page | Next Page
Pages: 1 2 [3] 4
Pump Power Requirements Spreadsheet Calculator
This spreadsheet allows the user to find the pump power requirement (Watts or Brake Horse Power) for various feeder pipe diameters (in) and given a known flow rate (LPS), pipe length (m) and head (m) and then select a suitable pump based upon available pump characteristic data.
Centrifugal Pump Requirements Spreadsheet Calculator
Calculates: Friction head loss on suction, Friction head loss on discharge, Dynamic head, NPSH, System power, Calculates and creates Pump vs Head Curve, Considers fittings and valves for both suction and discharge of pump, Allows for three separate application calculations
Liquid Pressure Drop in Pipe and Pipe Fittings Spreadsheet Calculator
Liquid Pressure Drop in Pipe and Pipe Fittings Spreadsheet Calculator. For the calculation of the friction factor the worksheet uses the Haaland equation which gives an implicit solution to the friction factor.
Control Valve P1 P2 vs Flow Spreadsheet Calculator
This worksheet approximates the behavior of P1 and P2 (pressure upstream and pressure downstream of a control valve) at different flow rates. This might be useful if valve Cv calculations need to be made at several flow rates, when only P1 and P2 are known at the maximum design flow and at zero flow. The principle behind the calculation is that pressure loss in a piping system is approximately proportional to flow squared. The worksheet may be freely copied and distributed to others.
Gas Compressibility Factor Spreadsheet Calculator
Vapor Pressure Spreadsheet
Vapor Pressure Spreadsheet Calculator
Hydrodynamic Noise Mass in Control Valves Mass Spreadsheet Calculator
IEC Hydrodynamic Noise Mass in Control Valves Mass Spreadsheet Calculator
Aerodynamic Noise Volumetric Control Valves Mass Spreadsheet Calculator
IEC Aerodynamic Noise Volumetric in Control Valves Mass Spreadsheet Calculator
Aerodynamic Noise in Control Valves Mass Spreadsheet Calculator
IEC Aerodynamic Noise in Control Valves Mass Spreadsheet Calculator
Control Valve 90 Deg Flow Spreadsheet Calculator
Control Valve 90 Deg Flow to Relative Travel Table Spreadsheet Calculator
Pages: 1 2 [3] 4
Disclaimer
