Convective Heat Gain Electric Appliances
Heat Transfer Engineering
Convective Heat Gain from Unhooded Electric Appliances During Idle (Ready-to-Cook) Conditions
The average rate of appliance energy consumption can be estimated from the nameplate or rated energy input qinput by applying a duty cycle or usage factor Fu. Thus, sensible heat gain qs for generic electric, steam, and gas appliances installed under a hood can be estimated using one of the following equations:
qs = qinput Fu FR
or
qs = qinput FL
where FL is the ratio of sensible heat gain to the manufacturer’s rated energy input. However, ASHRAE research (Swierczyna et al. 2008, 2009) showed the design value for heat gain from a hooded appliance at idle (ready-to-cook) conditions based on its energy consumption rate is, at best, a rough estimate. When appliance heat gain measurements during idle conditions were regressed against energy consumption rates for gas and electric appliances, the appliances’ emissivity, insulation, and surface cooling (e.g., through ventilation rates) scattered the data points widely, with large deviations from the average values.
The tables below lists usage factors, radiation factors, and load factors based on appliance energy consumption rate for typical electrical, steam, and gas appliances under standby (idle or ready-to-cook) and cooking conditions, hooded and unhooded.
Appliance
Energy Rate,
Btu/h
Rate of Heat Gain, Btu/h
Usage
Factor
FU
Radiation
Factor
FR
Rated
Standby
Sensible
Radiant
Sensible
Convective
Latent
Total
Cabinet: hot serving
(large),
insulateda
6,800
1,200
400
800
0
1,200
0.18
0.33
(large),
uninsulated
6,800
3,500
700
2,800
0
3,500
0.51
0.20
Cabinet: proofing
(large)a
17,400
1,400
1,200
0
200
1,400
0.08
0.86
Cabinet: proofing
(small 15-shelf)
14,300
3,900
0
900
3,000
3,900
0.27
0.00
Cheesemelterb
8,200
3,300
1,500
1,800
0
3,300
0.41
0.45
Coffee brewing urn
13,000
1,200
200
300
700
1,200
0.09
0.17
Drawer warmers,
2-drawer
(moist holding)a
4,100
500
0
0
200
200
0.12
0.00
Egg cookerb
8,100
850
200
650
0
850
0.10
0.26
Espresso machine*
8,200
1,200
400
800
0
1,200
0.15
0.33
Food warmer:
steam table
(2-well-type)
5,100
3,500
300
600
2,600
3,500
0.69
0.09
Freezer (small)
2,700
1,100
500
600
0
1,100
0.41
0.45
Fryer, countertop,
open deep fatb
15,700
1,500
700
800
0
1,500
0.09
0.47
Griddle, countertopb
27,300
6,100
2,900
3,200
0
6,100
0.22
0.48
Hot dog rollerb
5,500
4,200
900
3,300
0
4,200
0.77
0.22
Hot plate:
single element,
high speed
3,800
3,400
1,100
2,300
0
3,400
0.89
0.32
Hot-food case
(dry holding)a
31,100
2,500
900
1,600
0
2,500
0.08
0.36
Hot-food case
(moist holding)a
31,100
3,300
900
1,800
600
3,300
0.11
0.27
Induction hob,
countertopb
17,100
0
0
0
0
0
0.00
0.00
Appliance
Energy Rate,
Btu/h
Usage
Factor
FU
Radiation
Factor
FR
Rated
Standby
Sensible
Radiant
Sensible
Convective
Latent
Total
Microwave oven:
commercial
5,800
0
0
0
0
0
0.00
0.00
Oven:
countertop
conveyorized bake
/finishingb
17,100
13,500
2,500
11,000
0
13,500
0.79
0.18
Paninib
6,100
2,300
700
1,600
0
2,300
0.37
0.29
Popcorn popperb
2,900
400
100
300
0
400
0.14
0.24
Rapid-cook oven
(quartz-halogen)a
41,000
0
0
0
0
0
0.00
0.00
Rapid-cook oven
(microwave/convection)b
19,400
3,900
300
3,600
0
3,900
0.20
0.08
Reach-in refrigeratora
4,800
1,200
300
900
0
1,200
0.25
0.25
Refrigerated prep tablea
2,000
900
600
300
0
900
0.45
0.67
Rice cookerb
5,300
300
50
250
0
300
0.05
0.17
Soup warmerb
2,700
1,300
0
200
1,100
1,300
0.49
0.00
Steamer (bun)b
5,100
700
100
600
0
700
0.13
0.16
Steamer, countertopb
28,300
1,200
0
800
400
1,200
0.04
0.00
Toaster:
4-slice pop up
(large)
6,100
3,000
200
1,400
1,000
2,600
0.49
0.07
Toaster: contact
(vertical)b
8,900
2,600
600
2,000
0
2,600
0.29
0.24
Toaster: conveyor
(large)
32,800
10,300
3,000
7,300
0
10,300
0.31
0.29
Toaster:
small conveyorb
6,000
5,800
1,200
4,600
0
5,800
0.98
0.21
Tortilla grillb
7,500
3,600
900
2,700
0
3,600
0.47
0.25
Waffle ironb
9,200
900
200
700
0
900
0.10
0.22
Sources:
Swierczyna et al. (2008, 2009); with the following exceptions as noted.
a Swierczyna et al. (2009) only.
b Additions and updates from ASHRAE research project RP-1631 (Kong and Zhang 2016; Kong et al 2016).
References
  • ASHRAE Handbook of Fundamentals, 2021 Inch-Pound Edition
