Anti-Seize Compound Application Review |
Anti-seize materials and compounds are used on threads, bolted joints and even ACME thread installation. The goal of anti-seize is to prevent the threads from, well seizing and preventing the normal disassembly of the mechanical joint. |
Torque Values Stainless Steel Bolt Table Chart |
The following torque values are the maximums for for Stainless Steel and Nonferrous Fasteners based upon actual lab testing on clean and dry or near dry fasteners. For other friction conditions, significant modifications may be required. |
Calculating Assembly Torque per ISO 68 & ISO 724 |
The following assumes a metric thread form according to ISO 68-1 ISO general purpose screw threads -- Basic profile -- Part 1: Metric screw threads and ISO 724 ISO general-purpose metric screw threads -- Basic dimensions. |
