Uniform Loading on Horizontal Projected Area Pressure Vessel Formulas and Calculator
Any smooth figure of revolution if R2 is less than infinity Stress and Deflection Equation and Calculator.
Uniform loading, w force/unit area, on the horizontal projected area; tangential top edge support
Preview: Smooth Figure of Revolution Stress and Deflection Calculator
Smooth Figure of
Revolution
For R2 / t > 10 and θ ≤ 90°
Meridional Stress
Meridional Stress
Circumferential Hoop Stress
Rotation of a meridan from its unloaded position
Where used:
v = Poisson's ratio
w = Axial load or force applied (lbs/in2)
σ1,2 = Stress, (lbs/in2)
R1 = Radius (in)
R2 = Radius (in)
t = Wall thickness (in)
y = Vertical level from bottom of vessel (in)
θ = Angle (deg.)
