Moments and Reactions for Rectangular Plates using Finite Difference Method |
Moments and Reactions for Rectangular Plates using the Finite Difference Method. This book of monograph presents a series of tables containing computed data for use in the design of components of structures which can be idealized as rectangular plates or slabs. Typical examples are wall and footing panels of counterfort retaining walls. |
Mechatronics Technologies and Principles |
Mechatronics is an amalgam of “mechanisms” and “electronics”: systems that contain both mechanical and electrical components. It’s a field that spans nearly every industry, so any one source (even this one) will not be complete with all the information you need. |
Gear Design Handbook |
Fundamentals of Toothed Gearing, Spur Gears, Helical Gears. Gear Design Handbook |
Stress Analysis Manual |
Beams analysis, Column Analysis, Bar analysis, Trusses, Frames and Rings, Plates, Membranes, Pressure Vessels, Lug Analysis, Shaft, Bearing Stresses, Shafts, Bearing Stresses |
Mechatronics Design Engineering and Manufacturing |
Mechatronics is an amalgam of “mechanisms” and “electronics”: systems that contain both mechanical and electrical components. It’s a field that spans nearly every industry, so any one source (even this one) will not be complete with all the information you need. But this may be a good jumping off point. I’m writing this generally towards those in a competitive robotics environment, so will use many examples from there, but you soon find that those same technologies that shoot foam balls into goals can be used anywhere from assembly lines to emergency medical equipment or racecars. |
Applied Mechanics and Design |
Mechanics deals with application of forces and their effects on rigid bodies (without deformation) in rest or in motion. |
Servomechanisms Theory |
The purpose of a feedback control system is to monitor an output (controlled variable) in a manner dictated by an input (reference variable) in the presence of spurious disturbances (such as random load changes). |
