Heat Transfer Problems Solved Using Python Calculator
Heat Transfer Engineering
Heat Transfer Problems Solved Using Python Application and Calculator
This is a collection of Python scripts for heat transfer calculations for selected configurations shown below..
NOTE:
Refunds are not awarded after Python files have been downloaded - review your membership agreement for details.
​Units (if utilized) utilized within calculators are either SI or Imperial (some enable both SI and Imperial) and member (you) are responsible for conversions. Ensure that you verify units utilized in excel application meet your requirements before downloading.
Download: Heat Transfer Problems Solved Python Calculators
isolation-convection.py compares the temperature distribution on the problem as shown in the image below
Output
temperature distribution output
convection-convection.py is the solution of the wall under the conditions shown in the next image
Output
solution of the wall under the conditions shown output
heat_transfer_2d_steady-state.py is the solution of the following problem using finite difference method
finite difference method 1
finite difference method 2
Output
finite difference method output
Source
Support:
  • Engineers Edge has tested the basic functions and operation of this application using Python 3.11.9 and supporting modules.
  • THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
