Solid with Spherical Inclusions Effective Thermal Conductivity Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Effective thermal conductivity of a two-phase system
Preview: Solid with Spherical Inclusions Effective Thermal Conductivity Calculator
Construction of two systems that both contain within a spherical region of radius R' (a) the "true" system, a medium with thermal conductivity ko, in which there are embedded n tiny spheres of thermal conductivity k, and radius R; and (b) an "equivalent" system, which is a continuum, with an effective thermal conductivity keff. Both of these systems are placed in a temperature gradient A, and both are surrounded by a medium with thermal conductivity ko.
Tr = T + [ 1 - ( ( keff - ko ) / ( keff + 2 · ko ) · ( R / r ) 3 ] · A · r · cos (Θ)
T = Initial Temperature (K)
keff = Effective Thermal Conductivity (J/ft s K)
ko
= Thermal Conductivity of Solid (J/ft s K)
R =
Effective Radius (ft)
r
= Distance from Center (ft)
A
= Temperature Gradient (K/ft)
Θ
= Position of Substance from Center (rad)
Tr
= Temperature at R (K)
true discrete system
Figure 1a
equivalent continuum system
Figure 2a
Figures 1a and 1b thought experiment used by Maxwell to get the thermal conductivity of a composite solid: (a) the "true" discrete system, and (b) the "equivalent" continuum system.
  1. Bird, R.B., Stewart, W.E. and Lightfoot, E.N. (2002). Transport Phenomena (Second Ed.). John Wiley & Sons, Chapter: 11, Page: 371.
