Stopping Distance by Sight Calculator and Formulas
Engineering Applications
Car Stopping Distance by Sight Calculator SSD
A driver’s ability to see ahead is needed for safe and efficient operation of a vehicle on a highway. For example, on a railroad, trains are confined to a fixed path, yet a block signal system and trained operators are needed for safe operation. In contrast, the path and speed of motor vehicles on highways and streets are subject to the control of drivers whose ability, training, and experience are quite varied.
Sight distance is the length of the roadway ahead that is visible to the driver. The available sight distance on a roadway should be sufficiently long to enable a vehicle traveling at or near the design speed to stop before reaching a stationary object in its path.
Stopping sight distance is the sum of two distances: (1) the distance traversed by the vehicle from the instant the driver sights an object necessitating a stop to the instant the brakes are applied, and (2) the distance needed to stop the vehicle from the instant brake application begins. These are referred to as brake reaction distance and braking distance, respectively.
The stopping sight distance is the sum of the distance traversed during the brake reaction time and the distance to brake the vehicle to a stop. The computed distances for various speeds at the assumed conditions on level roadways To calculate SSD
Stopping sight distance on level road
Imperial Units
SSD = 1.47 V t + ( 1.075 V2 ) / a
where
SSD = stopping distance, ft
V = design or initial speed, mph
t = brake reaction time, typically about 2.5 s
a = deceleration rate, ft/s2 see note 1
Metric SI Units
SSD = 0.278 V t + ( 0.039 V2 ) / a
where:
SSD = stopping sight distance, m
V = design or initial speed, km/h
t = brake reaction time, 2.5 s
a = deceleration rate, m/s2 see note 1
Effect of Grade on Stopping
When a highway is on a grade, Equations 1 and 2 for braking distance is modified as follows:
Eq. 3
Imperial Units
dB = 1.47 V t + V2 / { 30 [ ( a / 32.2 ) ± G ] }
where:
dB = braking distance on grade, ft
V =design or initial speed, mph
a = deceleration, ft/s2 see note 1
G = grade, rise/run, ft/ft
Eq. 4
Metric SI Units
dB = 0.278 V t + V2 / { 254 [ ( a / 9.81 ) ± G ] }
where:
dB = braking distance on grade, m
a = deceleration, m/s2 see note 1
G = grade, rise/run, m/m
In these equations, G is the rise in elevation divided by the distance of the run and the percent of grade divided by 100, and the other terms are as previously stated. The stopping distances needed on upgrades are shorter than on level roadways; those on downgrades are longer. The stopping sight distances for various grades shown in the Tables below are the values determined by using Equations 3 and 4 in place of the second term in Equations 1 and 2. These adjusted sight distance values are computed for wet-pavement conditions using the same design speeds and brake reaction times used for level roadways.
Table 1 U.S. Customary Stopping Sight Distance on Level Roadways |
Design Speed (mph) |
Brake Reaction Distance (ft) |
Braking Distance on Level (ft) |
Stopping Sight Distance |
Calculated (ft) |
Design (ft) |
15 |
55.1 |
21.6 |
76.7 |
80 |
20 |
73.5 |
38.4 |
111.9 |
115 |
25 |
91.9 |
60.0 |
151.9 |
155 |
30 |
110.3 |
86.4 |
196.7 |
200 |
35 |
128.6 |
117.6 |
246.2 |
250 |
40 |
147.0 |
153.6 |
300.6 |
305 |
45 |
165.4 |
194.4 |
359.8 |
360 |
50 |
183.8 |
240.0 |
423.8 |
425 |
55 |
202.1 |
290.3 |
492.4 |
495 |
60 |
220.5 |
345.5 |
566.0 |
570 |
65 |
238.9 |
405.5 |
644.4 |
645 |
70 |
257.3 |
470.3 |
727.6 |
730 |
75 |
275.6 |
539.9 |
815.5 |
820 |
80 |
294.0 |
614.3 |
908.3 |
910 |
85 |
313.5 |
693.5 |
1007.0 |
1010 |
Table 2 Metric Stopping Sight Distance on Level Roadways |
Design Speed (km/h) |
Brake Reaction Distance (m) |
Braking Distance on Level (m) |
Calculated (m) |
Design (m) |
20 |
13.9 |
4.6 |
18.5 |
20 |
30 |
20.9 |
10.3 |
31.2 |
35 |
40 |
27.8 |
18.4 |
46.2 |
50 |
50 |
34.8 |
28.7 |
63.5 |
65 |
60 |
41.7 |
41.3 |
83.0 |
85 |
70 |
48.7 |
56.2 |
104.9 |
105 |
80 |
55.6 |
73.4 |
129.0 |
130 |
90 |
62.6 |
92.9 |
155.5 |
160 |
100 |
69.5 |
114.7 |
184.2 |
185 |
110 |
76.5 |
138.8 |
215.3 |
220 |
120 |
83.4 |
165.2 |
248.6 |
250 |
130 |
90.4 |
193.8 |
284.2 |
285 |
140 |
97.3 |
224.8 |
322.1 |
325 |
Note: Brake reaction distance predicated on a time of 2.5 s; deceleration rate of 11.2 ft/s2 [3.4 m/s2] used to determine calculated sight distance.
Table 3 U.S. Customary Stopping Sight Distance on Grades |
Stopping Sight Distance (ft) |
Downgrades |
Upgrades |
3% |
6% |
9% |
3% |
6% |
9% |
15 |
80 |
82 |
85 |
75 |
74 |
73 |
20 |
116 |
120 |
126 |
109 |
107 |
104 |
25 |
158 |
165 |
173 |
147 |
143 |
140 |
30 |
205 |
215 |
227 |
200 |
184 |
179 |
35 |
257 |
271 |
287 |
237 |
229 |
222 |
40 |
315 |
333 |
354 |
289 |
278 |
269 |
45 |
378 |
400 |
427 |
344 |
331 |
320 |
50 |
446 |
474 |
507 |
405 |
388 |
375 |
55 |
520 |
553 |
593 |
469 |
450 |
433 |
60 |
598 |
638 |
686 |
538 |
515 |
495 |
65 |
682 |
728 |
785 |
612 |
584 |
561 |
70 |
771 |
825 |
891 |
690 |
658 |
631 |
75 |
866 |
927 |
1003 |
772 |
736 |
704 |
80 |
965 |
1035 |
1121 |
859 |
817 |
782 |
85 |
1070 |
1149 |
1246 |
949 |
902 |
862 |
Table 4 Metric Stopping Sight Distance on Grades |
Stopping Sight Distance (m) |
Downgrades |
Upgrades |
3% |
6% |
9% |
3% |
6% |
9% |
20 |
20 | 20 | 20 | 19 | 18 | 18 |
30 |
32 | 35 | 35 | 31 | 30 | 29 |
40 |
50 | 50 | 53 | 45 | 44 | 43 |
50 |
66 | 70 | 74 | 61 | 59 | 58 |
60 |
87 | 92 | 97 | 80 | 77 | 75 |
70 |
110 | 116 | 124 | 100 | 97 | 93 |
80 |
136 | 144 | 154 | 123 | 118 | 114 |
90 |
164 | 174 | 187 | 148 | 141 | 136 |
100 |
194 | 207 | 223 | 174 | 167 | 160 |
110 |
227 | 243 | 262 | 203 | 194 | 186 |
120 |
263 | 281 | 304 | 234 | 223 | 214 |
130 |
302 | 323 | 350 | 267 | 254 | 243 |
140 |
341 | 367 | 398 | 302 | 287 | 274 |
Notes:
- Studies documented have shown that most drivers decelerate at a rate greater than 14.8 ft/s2 [4.5 m/s2] when confronted with the need to stop for an unexpected object in the roadway. Approximately 90 percent of all drivers decelerate at rates greater than 11.2 ft/s2 [3.4 m/s2]. Such decelerations are within the driver’s capability to stay within his or her lane and maintain steering control during the braking maneuver on wet surfaces. Therefore, 11.2 ft/s2 [3.4 m/s2] (a comfortable deceleration for most drivers) is recommended as the deceleration threshold for determining stopping sight distance. Implicit in the choice of this deceleration threshold is the assessment that most vehicle braking systems and the tire-pavement friction levels of most roadways are capable of providing a deceleration rate of at least 11.2 ft/s2 [3.4 m/s2]. The friction available on most wet pavement surfaces and the capabilities of most vehicle braking systems can provide braking friction that exceeds this deceleration rate.
- Brake Reaction Time. This is the time interval between when an obstacle in the road can first be physically seen and when the driver first applies the brakes. The assumed value is 2.5 s. This time is considered adequate for 90% of drivers in simple to moderatelycomplex highway environments.
- Speed. The SSD tables provide a minimum value which is based on the design speed.
- Grade Adjustment. AASHTO 's A Policy on Geometric Design of Highways and Streets provides values to adjust the SSD for each grade which, theoretically, affects braking distances. Due to the conservative SSD model and the nature of the State's terrain, the use of the grade adjustment is not required.
- Constant Acceleration and Motion Animation and Calculator
- Centripetal Acceleration Equations and Calculator
- Motor Car Engineering Text Book Volume I Construction
- Braking Torque Equation and Calculator
- Short-Duration Acceleration and Shock Loads Table
- Kinetic Energy Equation and Calculator
- Engine Power Transmission and Technology Menu
- Gear and Power Transmission Table
- Power Transmission Shaft Design Formulas and Calculator
- Analysis and Design of Automotive Brake Systems
- Tire Traction Force Equation and Calculator
- Transmission Gear Ratio Equation and Calculator
- Distance traveled on uphill or downhill gradients Equation and Calculator
- Gradability and Traction Equation and Calculator
- Vehicle Hill Climbing Gradability taking into Account Road Tire Adhesion Equation and Calculator
Source
AASHTO A policy on Geopmetric Design of Highways and Streets, 2018 7th Edition
