Toggle Clamping Mechanism Formula and Calculator
Toggle Mechanism Clamping Ninety Degree Reaction Points Design Formula and Calculator
Preview: Clamping Ninety Degree Reaction Points Toggle Mechanism Calculator
Q = P [ ( l + l3 · f + 0.06 · r · fo ) / ( l1 - l2 · f1 - 0.40 · r · fo ) ]
P = Q / [ ( l + l3 · f + 0.06 · r · fo ) / ( l1 - l2 · f1 - 0.40 · r · fo ) ]
Figure 1
Q = force applied to handle. lbf, (N)
P = clamping force, lbf. (N)
f = coefficient of friction of contact surface = 0.1 to 0.15
fo = coefficient of friction (axles and pivot pins) = 0.1 to 0.15
f1 = coefficient of friction of contact surface = 0.1 to 0.15
n = efficiency coefficient, 0.98 to 0.84
l, l1 l2 l3 = length as indicated. in, (mm)
r = radius of pivot hole. in, (mm)
Handbook of Machining and Metalworking Calculations
Ron A. Walsh
2001
