Honeycomb Core Wrinkling Stress Equation and Calculator
Structural Composite Honeycomb Core Wrinkling Stress Equation and Calculator
Wrinkling of Facings Under Edgewise Load of Honeycomb Core Calculator
Wrinkling of honeycomb facings, as shown in Figure 1, may occur if a honeycomb facing buckles as a plate on an elastic foundation. It may buckle into the core or away from the core depending on the relative strengths of core in compression and adhesive in flat wise tension.
Face Wrinkling
Figure 1, Face Wrinkling
The facings of a honeycomb shall not wrinkle under design load. The wrinkling stress formulas are given for two types of sandwich; sandwich with continuous cores and sandwich with honeycomb cores for which elastic-moduli in the plane of the core are very small compared with the elastic modulus in a direction normal to the core plane.
Determine parameter K from Figure 2:
Eq. 1a,
η/tc
Eq. 1b,
Fc / Ec
Eq. 2, From Figure 3 and using K value and ( Ec t / Ef tc )1/2 obtain Fcr / Ef
Eq. 2a
( Ec t / Ef tc )1/2
Eq. 3, Stress at which face wrinkling occurs:
Fcr = ( Fcr / Ef ) Ef
Where
Ec = core flatwise Modulus of elasticity, lbs/in2
Ef = Facing modulus of elasticity, lbs/in2
η = total amplitude of initial facing waviness usually between 0.005 - 0.005 inch
Fc = flatwise strength of core or bond, whichever is less
t = thickness of facing, in
tc = thickness core, in
λ = (1 - µ2)
µ = Poisson's ratio
K = See Figure 2
Figure 2
Figure 3, Parameters for determining wrinkling of facings of sandwich with continuous cores
Figure 4, Graph for the wrinkling stress of facings for sandwich with honeycomb cores
Source
Bell Helicopter Structural Design Manual, 1977
