Plastic Molding Tolerances Metric Calculator per. ISO DIN 16901
Plastic Molding Tolerances per. ISO DIN 16901
Using Table 1, the number specified refer to the tolerance group calculated in the chart calculator below.
(Requires Premium Membership)
General tolerances
If the deviations are not specified against the number for the dimension in production documents, order documents, etc. a note must be included referring to this standard, by specifying DIN16901 and the tolerance group given.
Example for specifying tolerance group 140:
Tolerances DIN 16901-140
Deviations specified against dimensions
Example showing division of tolerance 0,8:
Table 1 - Correlation of tolerance groups with molding materials
Symbol materials | Molding made from | Materials in
accordance with ISO DIN |
Tolerance Groups |
General Tolerances | Tolerances on dimensions with deviations entered against the dimension |
Series 1 | Series 2 | ||||
EP | Epoxy resin molding materials | 130 | 120 | 110 | |
EVA | Ethylene vinyl acetate copolymer molding materials | 16778 Part 1 | 140 | 130 | 120 |
PF | Phenolic plastic molding materials with inorganic fillers Type 11.5, 12, 13, 13.5, 13.9, 15, 16 | 7708 Part 2 | 130 | 120 | 110 |
Phenolic plastic molding materials with organic fillers Type 30.5, 31, 31.5, 13.9, 32.51, 51.5, 51.9, 52, 52.9, 71, 74, 75, 83, 84 | 140 | 130 | 120 | ||
UF MF |
Aminoplastic molding materials and aminoplastic/phenolic plastic molding with organic fillers Type 131, 131.5,150, 152, 152.7, 153, 154, 180, 181, 181.5 |
7708 Part 3 | 140 | 130 | 120 |
Aminoplastic phenolic plastic materials and amino plastic/phenolic plastic molding with inorganic fillers Type 155, 156, 158 |
Aminoplastic molding materials and aminoplastic/phenolic plastic molding with inorganic fillers Type 157, 182, 183 |
UP | Polyester resin molding materials Type 801,802,803,804 | 130 | 120 | 110 | |
UP | Polyester resin mats type 830, 830.5, 831, 831.5, 832, 832.5, 833, 833.5 | 140 | 130 | 120 | |
ASA | Molding materials based on acrylonitrile-styrine acrylester copolymers | 130 | 120 | 110 | |
ABS | Molding materials based on acrylonitrile-butadiene-styrene | 16772 Part 1 | 130 | 120 | 110 |
CA | Cellulose acetate molding materials | 7742 Part1 | 140 | 130 | 120 |
CAB | Cellulose acetate butyrate molding materials | 7742 Part1 | 140 | 130 | 120 |
CAP | Cellulose acetate propionate molding materials | 140 | 130 | 120 | |
CP | Cellulose propionate molding materials | 140 | 130 | 120 | |
PA | Polyamide molding materials (amorphous.with or without fillers) | 130 | 120 | 110 | |
PA 6 | Polyamide 6 molding material1) (without filler) | 140 | 130 | 120 | |
PA 66 | PoIyamide 66 molding materials1) (without filler) | 140 | 130 | 120 | |
PA 610 | Polyamide 610 molding materials1) (without filler) | 140 | 130 | 120 | |
PA 11 | Polvamide 11 molding materials1) (without filler) | 140 | 130 | 120 | |
PA 12 | Polyamida 12 molding materials1) (without filler) | 140 | 130 | 120 | |
- | Glass fibre reinforced polyamlde 6, 66, 610, 11and 12 molding materials1 | 130 | 120 | 110 | |
PB | Poly butylene molding materials | 160 | 150 | 140 | |
PBTP | Polybutylene terephthalate molding materials Without filler | 140 | 130 | 120 | |
Polybutylene terephthalate molding materials With filler | 130 | 120 | 110 | ||
PC | Polycarbonlte molding materials (without filler,with filler) | 1744 Part 1 | 130 | 120 | 110 |
PDAP | Polydiallylphthalate molding materials(with inorganic filler) | 130 | 120 | 110 | |
PE | Polyethylenemoulding materials1) (without filler) | 16776 Part 1 | 150 | 140 | 130 |
PESU | PoIyethersulphonemoulding materials (without filler) | 130 | 120 |
110 | |
PSU | PoIysulphonemoulding materials (with filler,without filler) | 130 | 120 | 110 | |
PETP | PoIyethyleneterephthllate molding materials (amorphous) | 130 | 120 | 110 | |
PoIyethyleneterephthalate molding materials (crystalline) | 140 | 130 | 120 | ||
Polyethyleneterephthllate molding materials (with filler) | 130 | 120 | 110 | ||
PMMA | PoIymethyl methacrylate molding materials | 7745 Part 1 | 130 | 120 | 110 |
POM | PoIyoxymethylene (polyacetal) molding materials1) (without filler), length of moldings: < 150mm | 140 | 130 | 120 | |
Polyoxymethylene (polyacetal) molding materials1) (without filler). 150 140 130 length of moldings: 150mm |
150 | 140 | 130 | ||
Polyoxymethylene (polyacetal) molding materials1) (with filer) | 130 | 120 | 130 | ||
PP | Polypropylene molding materials1) (without filler) | 16774 Part 1 | 150 | 140 | 130 |
Polypropylene molding materials1) (glass fibre reinforced, reinforced with talcum or asbestos fibre) | 140 | 130 | 120 | ||
PP/EPDM | Mixture of polypropylene and rubber (without filler) | 140 | 130 | 120 | |
PPO | Polyphenyleneoxide molding materials | 130 | 120 | 110 | |
PPS | Polyphenylenesulphide molding materials (with filler) | 130 | 120 | 110 | |
PS | Polystynllle molding materials | 7741 Part 1 | 130 | 120 | 110 |
PVC-U | Unplasticized polyinyl chloride molding materials | 7748 Part 1 | 130 | 120 | 110 |
PVC-P | Plasticized polyinyl chloride molding materials | 7749 Part 1 | No data available at present | ||
SAN | Styrene acrylonitrile molding materials (with finer, without filler) | 16775 Part 1 | 130 | 120 | 110 |
SB | Styrene butadiene molding materials | 16771 Part 1 | 130 | 120 | 110 |
Mixtures of polyphony and polystyrene (with and without filler) | 130 | 120 | 110 | ||
Fluorinated polyethylene-polypropylene molding materials | 150 | 140 | 130 | ||
- | Thermoplastic polyurethane, Products with 70 to 90 Shore A2) | 150 | 140 | 130 | |
- | Thermoplastic polyurethane, Products with over 50 Shore D2) | 140 | 130 | 120 |
Notes
1 In the case of unreinforced partly crystalline, non-hardening molding materials (thermoplastics the next highest tolerance group shall apply for wall thick nesses over 4 mm.
2 The word "moulding" was replaced with "molding" (US word) for internet searchability optimization.
Source
Plastic Moldings Tolerances and Acceptance conditions for linear dimensions per. DIN 16901
- Thickness of Wall and Ejector Marks Tolerance Calculator Grade E per. EN-10243-1 for Non-Circular Forgings
- Wall Thickness and Ejector Marks Tolerance Calculator Grade E per. EN-10243-1 for Circular Forgings
- Thickness and Ejector Marks Tolerance Calculator Grade F per. EN-10243-1 for Circular Forgings
- Thickness and Ejector Marks Tolerance Calculator Grade F Forgings
- Circular Forgings Tight Tolerance Calculator per. EN-10243-1
- Tolerance Table for Regularly Used Fits Excerpt from JIS B 0401 Table Calculator
- Snap Fit Tapered Finger Stress Application Calculates the Dynamic Strain of a tapered cantilevered flexing finger typically used in plastic snap fit type designs.
- Snap Fit Straight Finger Stress Application Straight beam dynamic strain equation and calculator
- Plastic Post and Hub Press Fit Equations / Calc. Press fits can be used with similar or dissimilar materials and can eliminate screws, metal inserts, adhesives, etc.
- Plastic Screw Design Equations and Calculator Theoretical equations to calculate the strength of plastic screwed joints.
