Plate Shear Buckling Stress Formulae and Calculator
Flat Plates Stress, Deflection Design Equations and Calculators
Plate Shear Buckling Stress Calculator and Equations
Critical Shear Stress at which a plate first buckles calculator.
Long Rectangular Plates. In 1891, Bryan (1891) presented the analysis of the elastic critical stress for a rectangular plate simply supported along all edges and subjected to a uniform longitudinal compressive stress. The elastic critical stress of a long plate segment is determined by the plate width-to-thickness ratio b/t, by the restraint conditions along the longitudinal boundaries, and by the elastic material properties (elastic modulus, E, and Poisson's ratio µ).
Preview Plate Shear Stress Buckling Calculator
The elastic critical stress, at which a plate first buckles, is expressed as
τ c r = K s π 2 η E 12 ( 1 μ 2 ) ( t b ) 2
A great deal of work has been done relative to the value of the plasticity correction factor. The expression for η must involve a measure of the stiffness of the materials in the elastic and inelastic ranges. A simple means of obtaining a value of η is to take the ratio of the shear secant modulus to the shear modulus.
η = G s D
Figure 1, Plate
Shear Buckling Coefficient, Ks
Figure 2, Shear Buckling Coefficient, Ks
Where
E = modulus of elasticity
Ks = non-dimensional shear buckling coefficient
η = plasticity correction factor
µ = poisson's ratio
c = clamped
s = simple supported
a = long side
b = short side
t = thickness
  • Bell Helicopter Structural Design Manual, 1977
