Plate Joints with Dissimilar Materials Loads Calculator and Equations
Fastener, Bolt and Screw Design Torque and Force Calculations
Sheet / Plate Joints with Dissimilar Materials Loads Calculator and Equations
When dissimilar materials are subjected to a uniform temperature change from the same initial temperature, T0, to a final temperature T and T2 , the loads induced into the clamped materials are as follows.
Preview Load Effects Due to Temperature Calculator
For heating of sheet 1 or cooling of sheet 2
P = α 1 ( T T 0 ) α 2 ( T 2 T 0 ) ( g 1 + g 2 ) / L 1 / A 1 E 1 + 1 / A 2 E 2 The force P will be compressive in 1 and tensile in 2
For heating of sheet 2 or cooling of sheet 1
P = α 2 ( T 2 T 0 ) α 1 ( T 1 T 0 ) ( g 1 + g 2 ) / L 1 / A 1 E 1 + 1 / A 2 E 2 The force P will be compressive in 2 and tensile in 1
Single Bolt
Figure 1, Single Bolt
Two ot Three Bolts
Figure 2, Two or Three Bolts
Where
A1 = Section area of plate 1
A2 = Section area of plate 2
L = length
g1 = gap plate 1
g2 = gap plate 2
E = modulus of elasticity
T0 = Initial temperature
T2 = final temperature plate 1
T = final temperature plate 2
α1 = Coefficient of thermal expansion plate 1
α2 = Coefficient of thermal expansion plate 2
P = load
  • Bell Helicopter Structural Design Manual, 1977
