Thermal Properties of Common Building Materials |
Thermal Properties of Common Building Materials. Some of the most important properties of building materials are their strength, weight, durability, and cost. In terms of energy conservation, their most important properties are their ability to absorb and transmit heat. |
Heat capacity of The Elements Table Chart |
This table gives the specific heat capacity (cp) in J/g K and the molar heat capacity (Cp) in J/mol K at a temperature of 25°C and a pressure of 100 kPa (1 bar or 0.987 standard atmospheres) for all The elements for which reliable data are available. |
Insulation Material Thermal Conductivity Chart |
Various Insulation Material Thermal Conductivity Chart R-values per inch given in SI and Imperial units (Typical values are approximations, based on the average of available results. Ranges are marked with "–". |
Thermal Conductivity of Liquids |
This table gives the thermal conductivity of some common liquids at temperatures between -25 and 100 deg. C. All values are given in units of watts per meter kelvin (W/m K). |
