Engineering Design Data: Menu - heat transfer
heat_transfer
  • HeatConductionPipeInsulation
  • heatlossinsulatedpipe
  • Prev Page | Next Page
    Pages: << 7 8 9 [10] 11 12
    Two Cylinders at Known Separation Equation and Calculator
    Steady State Rate of Heat Loss of Two Cylinders at Known Separation Equation. Two parallel isothermal cylinders placed in an infinite medium (L >>D1, D2 , z)
    Heat Loss Isothermal Cylinder buried in a semi-infinite medium
    Steady State Rate of Heat Loss of Isothermal Cylinder. Isothermal cylinder of length L buried in a semi-infinite medium (L >>D and z >1.5D)
    Heat Conduction Wall Equations and Calculator
    Variation in thermal conductivity of a material with temperature in the temperature range of interest can often be approximated as a linear function and expressed as:
    Heat Loss from Ducts Equations and Calculator
    Heat Loss from Ducts in a Building, basement or home Equation and Calculator. Include cost of energy loss.
    Overall Heat Transfer Coefficients in Heat Exchangers
    Representative values of the overall heat transfer coefficients in heat exchangers. Note that the overall heat transfer coefficient ranges from about
    Solar Radiation Incident on the Surface
    Hourly variation of solar radiation incident on various surfaces and the daily totals throughout the year at 40° latitude
    Water Boiling Graph Curve at 1 Atmosphere
    Natural Convection Boiling, Nucleate Boiling, Transition Boiling, Film Boiling
    Heat Loss Aluminum Framed Window Equation and Calculator
    Equations and calculator to determine the rate of heat loss through an aluminum framed window and the inner surface temperature..
    Surface Heat Transfer Coefficients Equations for Windows
    Heat transfer through a window is also affected by the convection and radiation heat transfer coefficients between the glass surfaces and surroundings.
    Heat Transfer Coefficients U-Factor for Windows
    Overall U-factors (heat transfer coefficients) for various windows and skylights
    Disclaimer
