Thermal Diffusivity Table |
In heat transfer analysis, thermal diffusivity is the thermal conductivity divided by density and specific heat capacity at constant pressure. |
Cooling Tower Water Treatment |
Cooling water systems remove heat generated from a variety of industrial processes. There are three basic types of cooling water systems: once-through, open recirculating, and closed recirculating cooling water systems. This publication describes once-through and open recirculating systems. |
Selecting Heat Sink Transistor Equation and Calculator |
Selecting a Heat Sink for a Transistor Equation and Calculator:
Assumptions:
1 Steady operating conditions exist.
2 The transistor case is isothermal at 90°C.
3 The contact resistance between the transistor and the heat sink is negligible. |
