Heat and Thermodynamics |
The study of any special branch of physics starts with a separation of a restricted region of space or a finite portion of matter from its surroundings. The portion which is set aside (in the imagination) and on which the attention is focused is called the system, and everything outside the system which has a direct bearing on its behavior is known as the surroundings. |
Saturated Water Entry Tables |
Thermodynamic Properties of Saturated Water Entry Tables, Specific Volume and Internal Energy for Pressure between 0.6113 - 800 kPa, and Temperatures between 0.01 - 170.43 °C |
Treatise on Thermodynamics Dr. Max Planck |
The oft-repeated requests either to publish my collected papers on Thermodynamics, or to work them up into a comprehensive treatise, first suggested the writing of this book. |
Horizontal Cylinder Natural Convection Equation and Calculator |
Heat transfer coefficient, heat convected and heat radiated from an isothermal horizontal cylinder assuming natural convection. The convection calculation is based on Rayleigh number and is valid for Rayleigh numbers between 10-5 and 1012. The ends of the cylinder are assumed to be adiabatic. |
Horizontal Plate Natural Convection Equations and Calculator |
Horizontal Plate Isothermal Heated Natural Convection Equation and Calculator. Average heat transfer coefficient and plate temperature for an isothermal (constant temperature) heated horizontal flat plate's lower surface or a cooled plate's upper surface in a natural convection environment. |
